Mudd bogger with Starter Problems
Discussion in 'The Garage' started by Lane, Apr 23, 2004.
  1. Lane
    Lane Registered Member
    Mar 19, 2003
    13
    Montevideo,MN USA
    I cant seem to get a stock starter to last in my mudd truck.
    Anyone know a good way to make um last or do I need to upgrade?
    MN MUDD BOGGER
    79Chasis, with 86body, 6"susp,2" body, 37"Boggers, 350 vortec,comp cam, perf intake, eddlebrock carb, TH400, NP203, GM14 bolt, Gm 10bolt.
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Whats happening to them? Dead, turns over slowly...? How often do they go bad?
  3. Lane
    Mar 19, 2003
    13
    Montevideo,MN USA
    It wont start when hot-just turns over slowly then eventually strips the gears. Ring gear is new and the starter works fine when cold. I have headers, so Im thinking that its getting hot, but I cant fiqure out why its stripping the starter gears when it starts turning slow, even though its is properly shimmed.
  4. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Try a heat shield and/or a Ford solenoid upgrade, both can be found in a Summit catalog. /forums/images/graemlins/thumb.gif
  5. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Evidently the starter is staying engaged briefly after the engine starts, I dont know how else the starter gears would strip if its shimmed correctly /forums/images/graemlins/dunno.gif Probably its getting heat soaked from the hot headers, try wrapped the solenoid in heat resistant material and installing a heat shield. You can get this stuff from speed shops or move the solenoid up inside the engine bay using a Ford solenoid. /forums/images/graemlins/thumb.gif
