Muffler Question
Discussion in 'The Garage' started by B_to_C, Mar 29, 2005.
  1. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    I have a Flowmaster 50 series muffler. It is single inlet, dual outlet. Can I Cap one of the outlets with no harmful effects? I want to jusst cut off my drivers side tail pipe because it gets in the way of my shock and spring as you can see...
    In this picture it actually dented my shock so badly it blew theseal and I had to buy a new shock.
  2. matto
    matto Registered Member
    Feb 20, 2005
    49
    uncasville ct
    the only thing that comes to mind is that it will restrict the flow of the muffler. it may not preform as well if you cap it.
  3. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    why not just reroute the pipe? run it straight out the back or dump them in front of the back tires...
  4. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    Nick, you know how my exhaust is. You could do something similar. Just cut both pipes off and put some 90* turndowns on the ends and angle them out toward the tire.
    I did several road trips with the windows rolled up and no heater on, and there was no exhaust fumes. I even carrier or carbon monoxide sensor with us on a couple of trips.
    You could at least put a turndown on the pipe in question.
    P.S.-You need to clean out your PMs. :mad:
