muffler question
Discussion in 'The Garage' started by aknight_sa, Oct 18, 2006.
  1. aknight_sa
    aknight_sa 1/2 ton status
    Oct 14, 2005
    305
    Saudi Arabia
    hi guys,
    befor i changed my engine from a SB 350 to a BB 454 but i still use my old mufflers (two standard ones)... will such a thing damage the engine as it might not give enough airr flow out of the engine or not?
    thanks
  2. draggbody
    draggbody 1/2 ton status
    Jul 13, 2005
    282
    columbus GA
    they will work, but not as efficently as you might want... especially going to a BB... if it is mostly stock i would run at least 2.5 in pipe... if it is "built" go w/ the 3"...
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    won't damage anything. May be fine, what size pipe are you running and are they factory duals or an aftermarket system?
