mufler.
Discussion in '1982-Present GM Diesel' started by eightyone, Jul 14, 2005.
  1. eightyone
    eightyone 1/2 ton status
    Apr 25, 2004
    292
    long island
    do you need to run a mufler on a diesel? and will you get little more power if you run like 4 inch straight pipe? im tryin to squeeze everything i can out of this 6.5. thanks for any input.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    It's always better to run a muffler or at least a decent length of pipe.
    If you go bigger however you do get better breathing with a diesel unlike the gassers which like some backpressure.
    4" might be overkill but lots of the guys run 3" I have 3.5"
    But then again I have a turbo.
    :D
  3. eightyone
    Apr 25, 2004
    292
    long island
    interesting. i am running a turbo as well, thats why i thought back pressure was not goin to help at all. i was talking to a friend who is into imports, and he has an external wastegate, or something, i think thats what its called, anyway, when he has full throttle, it opens, and the exaust dumps right out after the turbo, to release pressure, and keep it spooling easeair. does this sound right? and would it work the same way with a diesel? or am i wrong? im still learning about this stuff, so bear with me. thanks.
  4. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    You do have correct information.
    However there is more to it than that.
    The long tubes or a muffler will contain any unburnt fuel and let it burn and still use the power.
    Plus it will protect your ears and the surroundings from burning from sparks or so.
    A turbo will muffle the noise a bit so you could run a trubo with no muffler but would be better with some tubes.
    At least have 4-5 feet of tube behind a turbo.
    with no Turbo run full length tubes I mean full length of the truck.
    My buddy has that on his crew cab and it doesn't sound too bad and runs great
