multi function switch fix??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bklynlifted, Feb 13, 2002.
  1. bklynlifted
    bklynlifted 1/2 ton status
    Feb 4, 2002
    261
    brooklyn ny home of the brave
    cruice control not working and have narrowed it down to the multi function swithch!!!! now whats involved with to remove and replace?? any special tools or an easy fix??? thankx for advice on the diagnosis on cruise problem and carrier bearing fix .
  2. dyeager535
    26,979
    You are talking about the piece that the turn signal lever "plugs" into? You just have to rip the column apart. Link in my sig has a write up on how to tear the column down aways, theres other write ups on here if you do a search, as well.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. Eagle
    Eagle Registered Member
    72
    Suprise, AZ
    My cruise control hasn’t worked for years. Nor do I care. (it’s a trail truck) but I just got an idea. Can I use that push button for… say… turning on my trail lights? What would be involved?
    <font color=red>The secrete of marriage:</font color=red>
    <font color=blue>Find a woman that will kill you the slowest.</font color=blue>
