multi function switch in s-10
Discussion in 'The Garage' started by 89newtome, Jan 28, 2007.
  1. 89newtome
    89newtome Registered Member
    Apr 28, 2005
    23
    Enfield,CT
    how hard is it to change the multi function switch in a 86 s 10 blazer. My high beams stay on all the time and I do not hear the switch click when trying to switch to low beams. I am pretty sure it is the switch. but if anyone has any other thoughts let me know. thanks
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    easy, steering column trim comes off, screws come out, switch assy comes up, connectors removed, reversed, good to go
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The actual switch for the high/low beam selection is mounted on top of the steering column, under the dash. You don't have to remove the multi-function switch at all to replace it. There's a steel rod that goes down to the switch. If you watch closely while operating the lever, you'll see the rod moving and the switch that it attaches to.
  4. 89newtome
    Apr 28, 2005
    23
    Enfield,CT
    thanks for the help. now just got to buy the parts. thanks again
