multi shocks
Discussion in 'The Garage' started by adamforsythe, Nov 10, 2004.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    How many of you guys have multi shock set up on the front and in the back of your trucks?
    ADam
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I belive 1 shock per corner is pleanty.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    They are not really necessary unless you fo alot of high speed stuff with a soft suspension and big tires, just stick with the single shock, it works good /forums/images/graemlins/thumb.gif
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I have duals front and rear, if I remember correctly, it is a rancho front bracket, and a rear trailmaster bracket.
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    multi shocks
    Suck. Like someone already said, not necessary unless you're doing your Ivan Stewart impression, and even then, get a real shock and leave it at that. Don't see too many rigs with more than one shock at each corner unless they are the higher end desert rigs.
  6. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I 'had' dual shocks in the front, but recently removed them because what I have heard here. Let me tell you that it is awesome having 1 per corner, way better on and offroad. Now time for monotubes /forums/images/graemlins/peace.gif I am never going duals again!!! /forums/images/graemlins/truck.gif
  7. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    First thing I did when I lifetd the Blazer was lose the dual front shocks. One per corner is plenty!
  8. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I'm going to very timidly be the lone wolf here. My truck has the "quad 4" suspension package (4 shocks) up front from the factory. I have driven blazers without this and in my opinion they do not drive nearly as good. My truck does not have nearly the amount of "sway" in a turn as one without this package does. However, I do not do alot of "wheeling", but I do use my truck as a daily driver and travel in it, so how it drives on the road is probably more important to me than to alot of the guys in here. There is no doubt that most guys in here know much more about K-5's than I do. I just thought I'd give you my opinion.
  9. 84caddyvert
    84caddyvert Registered Member
    Nov 5, 2004
    11
    i had duals and took them......truck rides much better and is not quite like riding a brick.......
  10. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    You more than likely have crap shocks or the very rare setup where the two shocks are actually valved for the application.
    Learning about shocks, a person will discover what's behind them and will find out that dual shocks are a waste, except in the most extreme of circumstances.
  11. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    OR if you're one of those show truck guys....because obviously having 18 shocks per corner makes the truck cooler..... /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/rotfl.gif
  12. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Well I guess the good old Blazer is going to stay a one shocker per side.
    Thanks for the info
    Adam
  13. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Somebody give my show truck (with the primer door) a hell yeh! /forums/images/graemlins/rotfl.gif
