multi spark ingnitions?
Discussion in 'The Garage' started by great scott, Feb 2, 2003.
  1. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    who's running them,do they help with low end grunt,how harsh is the rev limiter, wich one do you like best?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    MSD. I love mine. I have also heard good things about DUI.
  3. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I had an MSD 6AL, and it helped quite a bit with the low end performance, smoothed out my idle, and increased my MPG by about 2 miles per gallon. The rev limiter feels a lot like valve float. Not too harsh.
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    We've run both the MSD 6A and the Crane HI-6 on the dyno. Can't say there's much difference in HP. They're about equally priced, but the HI-6 comes with the rev limiter built in. To get a rev limiter from MSD costs extra and even then it isn't as easy to dial in the limit RPM.
    Above about 3000 RPM there isn't enough separation in the ignition pulses for it to be truely multi-spark. What you have then is just a really long duration spark.
    To my knowlege the DUI isn't a multi-spark module, that is if we're talking about their replacement for the stock HEI module. It does have far superior dwell over a stock module. In a side by side comparison btwn a DUI module and a Delco module, both had 45* of dwell at idle. The Delco module started tapering off and at ~2500 RPM it was down to 35-36* of dwell. THe DUI module we tested had 45* of dwell as high as we were willing to wing that engine.
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have the whole MSD system.
    Pro billet distr., 6 series offroad box, rev limiter (it's a seperate box), and MSD 8.5 wires.
    I like it a lot and it's way overkill for my 350. It has been some time since I put it on, but I know the idle is much better and it starts quicker too. It feels smoother in general.
    MSD says above 3000 rpm there is not enough time for a multiple spark, so it is only one spark.
    A lot of people say aftermarket ignition stuff is not worth the money and frankly they are probably right. A brand new MSD or whatever brand HEI will cost about the same as just the 6 series offroad box and will perform almost as well.
    I still like mine.
    -- Mike
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    DUI isn't multispark (as far as I know) but it throws alot better and hotter spark. Not to mention the fact that the module is programmed for your exact setup motor wise. You tell them what you have and they build a module for your specs. I talked to Toby (Moneypit) about his and he really likes it alot.
    I personally like the MSD. It has worked very well for me. It is pricey, but it makes my motor run alot better then it did. Idle, mpg, starting, etc.
    Harley
  7. great scott
    Dec 31, 2002
    333
    Utah
    My wife hates your advice on this one, a local parts store has been twisting my arm to take a specail order some one didnt pick up on a mallory hyfire VIAL off there hands. The price at 105.00 is better then sumit at 169.95 and now you all have nothing but good to say about them. Sounds like a no brainer.
  8. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Never used the Mallory system. I have used the MSD 6al and the 7al race series. WELL WORTH THE MONEY. Does that mallory unit have a rev limiter In it? I say get it.
