muncie 4speed
Discussion in 'The Garage' started by chevyjunky77, Oct 6, 2003.
  1. chevyjunky77
    chevyjunky77 Registered Member
    Oct 6, 2003
    10
    Ft. Campbell KY
    Hello to all my fellow 4X4 brothers.
    ?#1 Does anyone have info on modifying(or a business that can do it) a muncie 4speed w/granny gear to change the ratio from 1. to a .8 or so in fourth. I am looking for better highway gas mileage.
    ?#2 Is there a web site that can decipher option codes, engine/axle codes and so forth.
    thanx
    chevyjunky77
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    #1- look for a NV-4500 or add an aftermarket OD. There is no option for changing the gear ratio in your SM465. You can however regear both of your axles or go to taller tires for the overdrive effect...
  3. chevyjunky77
    Oct 6, 2003
    10
    Ft. Campbell KY
    what is a nv-4500
  4. kennyw
    Jun 9, 2002
    13,224
    94
    NV4500 is a 5 spd manual transmission that was used in 1994 and up GM 4x4's. It will bolt inplace of your SM465 but you need the kit Advance adapters sells to put a NP205 behind one.
  5. chevyjunky77
    Oct 6, 2003
    10
    Ft. Campbell KY
    do you happen to know the ratios
  6. kennyw
    Jun 9, 2002
    13,224
    94
    The earlier GM versions were a low gear of 6.3x:1 or something like that, 4th is 1:1 and 5th is about 0.73:1.
  7. dyeager535
    26,982
    191
    Almost the exact same gear spacing as the 465, but with the added overdrive.
    Changing tire size or rear gears makes a big difference for a LOT less money than swapping in the NV4500. I'm assuming if you are worried about economy, you aren't too worried about wheeling? (no offense of course)
  8. chevyjunky77
    Oct 6, 2003
    10
    Ft. Campbell KY
    I dont need the high gears for that. It is that I drive I dont trailer.
  9. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    If you really wanted to spend money you could get a Ranger Overdrive, but I doubt you'd ever make up for what you pay for it in gas savings. Best bet is to get taller axle gears. With the sm465, you can afford to run lower axle ratios because of the granny gear and 3.58 2nd.
  10. chevyjunky77
    Oct 6, 2003
    10
    Ft. Campbell KY
    Im running 373. I guess Ill just live with it
  11. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    must be nice with 3.73's i have 3.08's with 33's and a 465 /forums/images/graemlins/ignore.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
