Murphy strikes again
Discussion in 'The Garage' started by RootBreaker, Jun 14, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    You know just when things start going the right way... Someone invites "Murphy"
    he needs to stay away.. maybe sign a restraining order or something....
    got my new alt in (140 upgrade didnt go so well :crazy: ) so stocker in there fo now
    fixed rear disc brakes... work perdy good but still need adjustable port valve...
    anyhow... walked to my truck yesterday.... goto open the door...
    push button in.. and door doesnt open.. also seems funny... lightly press button and you can hear the rod clankin in the door....
    DOH!!!! I HATE YOU MURPHY!!!!!
  2. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    I know a fellow that his last name is Murphy and he is in the lawn care buisness and on the side of his truck he has
    Murphy's Law-n :D
    I need to get a bigger altenator on my 84... So tell me what trouble your having putting yours on ?
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    Forget the resistor and blow the alternator up?
    These are the directions that were given to me in regards to setting my 80 up with a 105 amp alt from a newer Chevy truck:
    "terminal with the white wire on it goes to the battery (red wire on your current alt). On the 4 terminal plug the wire in the largest terminal (1 large,3 small) is the voltage sensing wire this can go to the same place (the terminal block by the battery). The other wire is a little more tricky, it depends if you have a warning light or not. If you have a warning light it would go to that, on the terminal opposite the terminal that goes to the ignition. If you do not have a warning light the brown wire on you alt will go there, BUT THROUGH A 75 OHM 3 WATT RESISTOR. DO NOT HOOK TO 12 VOLT OR YOU WILL NEED ANOTHER ALT. Again splice a resistor in series with the brown wire before it connects to the alt. You can probably purchase one at Radio Shack."
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    I bought the ac delco plug...
    ran white wire to fusebox for juice with key... then brown wire to my other wire..... that is it.... autozone tested he alt and said it was good... put the factory alt in and charges.. just cant get the 140amp alt working... but really do not require a 140 amp alt yet...
