Must push door handle button before un-locking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddbogg89, Mar 21, 2002.
  1. muddbogg89
    muddbogg89 Registered Member
    Mar 19, 2002
    97
    Chicago(suburbs)
    my power door locks dont work.And sometimes you have to press the door handle button to be able to turn the key.Also if the door gets locked while inside you can"t pull the lock stem up(I have to roll down the window to press the outside button to pull it up) this is very annoying!
    Any ideas? Thanks!
  2. Parf
    Parf Registered Member
    Nov 16, 2001
    81
    Golden, Colorado
    This problem happens to me too. WTF? Anyone know the cure. Or even the problem?
  3. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Your door unlock mechanism is sticky. Pull the cover off, clean and lube up the mechanism, bet it goes away, mine did. Got sick of the old lady raggin on me about it so I had to fix it.
  4. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Yep my 84 is the same way. There was a post on this about a year and half ago with a lot of responses you might do a search on it and see about easy solutions. I just deal with as a matter of fact I'm so use to it I push in the handle before I even slap in the key. It's just a habit now.
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    yeah, mine does it too. If I try to open the door from inside while its locked, I'm screwed...I have keyless entry. so I don't worry about the key in door part.
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    This happens to me to, I don't really think about it anymore.../forums/images/icons/crazy.gif
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    My burb has the same problem, but not the Jimmy /forums/images/icons/smile.gif
  8. steve_97
    steve_97 Registered Member
    Feb 27, 2002
    25
    Boise, Idaho
    same problem on my 73 k5, i just live with it.
  9. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Yep....... happend to my '84 K20 too.... but then i sold it and bought my blazer. Dont know what your gonna do ? /forums/images/icons/smile.gif
  10. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    my sub does it i'm used to it now but if i'm inside and it gets locked, i have to roll the window down and reach out, push the button and hit the switch again.
  11. muddbogg89
    Mar 19, 2002
    97
    Chicago(suburbs)
    do your power door locks work?
  12. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I just live with it since i am the only one that drives it. And nobody else can ulock it.
  13. Tuff84blaze
    Tuff84blaze 1/2 ton status
    May 12, 2000
    119
    Liberty Lake, Washington
    My 84 blazer does this too,but I like it because it is a theft deterant. Also to open it from the inside all I have to do is pull on the handle and let it spring back real fast, this usually works to get the lock unstuck.
  14. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    That's funny Dan your Jimmy has no doors.
  15. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    my power locks work, at least they kind of do. They unlock but won't lock, but thats just a connection problem.
