MUTHAFU#@$% DOOR HANDLES
Discussion in 'The Garage' started by tayv, Jan 29, 2004.
  1. tayv
    tayv Registered Member
    Apr 3, 2003
    58
    Seattle, Wa
    I have been avoiding posting for help on this because I just know that it is going to be easy. I cannot get the flippin door handles off of my 76 K5. So, please help me so I can paint my truck. Thanks-
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hmm i did this a while back...but the bolts should both be there behind the door panal.. /forums/images/graemlins/thinking.gif
  3. tayv
    Apr 3, 2003
    58
    Seattle, Wa
    I took both of the bolts off and the handle is hanging there. But I cannot unhook the rod that connects it to the mechanics of the door
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Our we talking about the outside or inside?
  5. tayv
    Apr 3, 2003
    58
    Seattle, Wa
    I have taken both nuts off of the inside, and so the handle will pull away from the door. But I cannot figure out how to completely unhook it. it is still attatched by the rod that attatches to the mechanics of the door. Either way, inside or out, I just want to pull the handle off so I can finish sanding and paint it
  6. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    should be a simple clip that the rod goes thru the clip and the inside lever. then it flips down and clips on the rod.. tho its been awhile since i took mine apart..
  7. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Yep...those clips usually rust-up...
    PB Blaster is what I had to use to get mine off last week..
    My clip just would slide on the latch mechanism...
    But after soaking that thing down..I got it to move..
    It helps to have a nice pick set..
    I used my hook style pick..and a long flat blade screwdriver.. /forums/images/graemlins/wink.gif
