My 110 volt socket
Discussion in 'The Garage' started by BranndonC, May 1, 2002.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    looks good man. you just rewire an invertor?
    grant
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    yeah, i wasn't going to use a switch, but the inverter has a built in fan, so it would pull power all the time without a switch.
  4. Heavymetal
    Heavymetal 1/2 ton status Premium Member
    Mar 30, 2001
    936
    Oregon
    I like it. You could also get a grey outlet, or one of those metal outdoor outlets with covers. Where did you locate the actual invertor?
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    walmart, it was $50 and 400 watts constant and 800 surge/max
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    walmart didn't have gray there.
  7. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I would go by the hardware store and get the "outdoor" grey metal cover that has flip up spring loaded caps. Other then that she looks good. Nice work!
  8. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    what would be the advantage of that? i think it would look too big and bulky.
  9. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    My blazer is Herculined and I wash it with a pressure washer. The advantage would be known the first time I washed it and got water in the socket. Plus if you ever have the top off and it starts to rain ;-(
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I got High Voltage too I can run an air compressor and most tools. But more imporntant it will run a Blender /forums/images/icons/laugh.gif
    Pic:<a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze/abi>Caution High Voltage</a>
    I have sence moved my invertor under the passenger seat its better protected there and more solidly mounted. Now I can mix a Margarita without stopping /forums/images/icons/crazy.gif
  11. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Cool!
    I have always wanted an inverter. So what is the smallest you would go when buying one? I would use it for tools and camping. Can you run AC powered stuff for long periods, like a tv? I guess the truck would need to be started from time to time to keep the batt from going dead.......
    Cool stuff
  12. Heavymetal
    Mar 30, 2001
    936
    Oregon
    When I said locate, I meant where in the vehicle.
  13. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    you can get water tight outlets from any marine supply store such as West Marine. A 15 or 20 amp/125volt plug wil work. You can get the outlet covers that screw down over the plug in either stainless steel or yellow plastic these will withstand normal water, and survive all but a dicect blast buy a pressure washer.
  14. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    I think 800 watts(continious power) is the smallest I would go for camping and general needs. That will run a small tankless compressor small power tools, TVs and small appliances that dont use over 7 amps
    My 1000 watt will run a motor up to 1/2 hp. it has quite a bit of power. At 1000 wats it will eat up a battery in under 2 hours. but it will last at least 4 or 5 hours running a small TV and still start the truck. It also has a low voltage warning light/alarm and auto shut down.
    I got it to run my onboard air compressor. I had to go with an electric compressor because I wanted to be able to air stuff up fast and did not want to give up my air conditioning. Its kind of handy to have power anywhere my truck is.
    heres where I got my invertor form <a target="_blank" href=http://www.northerntool.com/cgi-bin/ncommerce3/ExecMacro/NTE_SEARCH.d2w/report?KEYWORDS=inverters&amp;PHOTOS=on>northerntool.com</a>
    They have good prices on stuff.
  15. ratpack7
    ratpack7 Guest
    I was going to mount one of the outdoor gray ones to my tube bumber when I get it made.
    so theres power inside and out.
  16. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    how do you guys wire the inverter into the wiring?
    i was thinking of putting the inverter under the dash and having an outdoor plug in the dash somewhere...diagrams are good for us wiring idiots/forums/images/icons/crazy.gif
  17. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    red went to battery, and black to a good ground spot, i know you knew that, but that's all i really did!
