My 1990 sub wont start, need a little help please.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Sep 5, 2002.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    Its been 2 years since I logged on (No problems at all with my rig) However, I just tried to start my beast and it just cranks over no combustion. I'm thinking fuel pump but I thought I'd better ask first. Should you be able to hear the pump with the ignition in the on position? Is there a designated fuse for this? She ran great before I parked her 2 days ago. Yes, there is plenty of gas in the tank. Thanks.
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    Yes, fuses are a good place to start. Check fuses for fuel pump and ignition. You may have also lost the "pump prime" relay. If so, it would still start after you crank the engine long enough to get some oil pressure.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    check your ignition module and pick up module in the distributor. make sure there is a spark. Pull out a spark plug and keep the wire connected. Ground it against the block or something else ,and try to start. if there is no spark, its an ignition problem, otherwise, probably fuel.
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Have someone spray some starting fluid down the throttle body (or dump a little gas in) while you try to start it. If it starts then, it is a fuel problem. Make sure the fuse and relay are good first, then replace the bad pump.
  5. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    You should be able to hear the fuel pump come on. When you start it, turn the key to "on" and leave it there for a second. You'll hear a little whine and a little click. That's the fuel pump. I would check for spark though.
