my 6.2 injectors are still leaking!!
Discussion in 'The Garage' started by Pookster, Jul 19, 2005.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    So, I thought it was my injectors. Changed all the injectors, and guess what? It is still leaking. Maybe I have to change that little 0-ring?
  2. ksmeltzer
    ksmeltzer Registered Member
    Jan 24, 2005
    15
    Florida
    Did you use the old o-rings? If so I would replace them and see if it corrects the problem.
  3. cycochevy
    cycochevy Registered Member
    Jul 2, 2005
    9
    pa
    leak
    are they leaking fuel or compresion? fuel could be the fuel return lines. or it could be the small stems the return hoses go on to, ive seen them crack if you use the wrong socket to install..
