My 700R4 is being rebuilt...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89GMCSuburban, Feb 12, 2002.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Dropped it off at 9 AM, they had it out at 1PM and called me to tell me what the problem was. Remember the knocking noise I had? It was the flywheel, but it wasn't cracked. The weights were bent and that was making the noise. That part is $75. The planetaries and the sun shell are also bad which adds $85 and $65 to the price. On top of that the speedo gear is excesssively worn and need to be replaced, labor for that is another $75. Grand total from the original $495 quote, it is now $795. This thing better last me...
    Red 1989 GMC Suburban SLE V1500 - TBI 350, 700R4 w/ shift kit, Quad-shock front, 31/10.50/15 Pro Comp MT, 4.10 gears, Duals off cat
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    I know that's a lot of money, but a friend of mine recently had his 4L60 rebuilt in his '94 ext cab shortbed to the tune of $1800!
    When my 4L80E was rebuilt in my Sub, it cost $2200...of course nothing short of draining the fluid and running it dry can break it now! (knock on wood)
    Haze gray and underway...<font color=blue>or blue, in my case.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/abshort>U.S.S. Nimitz II</a>
  3. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Even that, my TH400 in my 67 C10 has blown rubber tranny cooler lines twice, each time losing 10 quarts. Refilled it, kept cruising down the road.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    The only cheap transmission work is installing shift kits and changing the fluid.
    I put $500 into mine just for parts. A 700 rebuild with full labor (tranny still in truck) is usually over $1000
    But even with that in mind, $75 dollars labor for changing the speedo gear is kind of silly.
    <font color=green>Top signs you don't have a real 4x4:
    4) Twin Traction Beam
    3) Made by D.C.
    2) 5 lug nuts
    1) Unibody</font color=green>
  5. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    in the 'For what it's worth' department, I paid $1700 for my GM re-man unit with a 3/50 warr on it. That was installed by local 4x4 shoppe in Colo Spgs.
    Your's sounds a lot less expensive!
    Gray 1991 Chevy Sub Silverado 1500 4x4, TBI 350, 700R4, Quad-Shock front, 4:10 in 3/4 ton axles F&amp;R.
  6. 91gmcjimmyCH_IL
    91gmcjimmyCH_IL 1/2 ton status
    May 24, 2001
    110
    Grayslake, IL
    I asked a local shop how much it would be to rebuild my 700r4 and they said around $1300. I also found out that if I pulled it myself and dropped it off to them they would take 300 bucks off the cost. Anything to save money.
