My '72 sbc 350 block the same as new ones?
Discussion in 'The Garage' started by roostr3269, Mar 28, 2002.
  1. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    My \'72 sbc 350 block the same as new ones?
    I have the original 350 out of my Jimmy that i replaced w/ the 502. My friend wants to buy it, if the block is the same as the new ones, so he can swap new parts on the old style block. Anyone know? thanx.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Re: My \'72 sbc 350 block the same as new ones?
    "New Ones"??
    No, they are different. You have two piece seal type and one piece seal,crank seal.
    There are other differences too but I don't know very much about blocks yet, still learning. But I do know that GM switched from a two piece crank seal to a one piece, I think it was early to mid 80s but I could be wrong.......
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I think 1986 ws the year that GM adopted the 1-piece rear main...
    Chris
  4. Burt4x4
    6,854
    That sounds about right cuz GM whent to FI about that time too, didn't they?
  5. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    86 was the first year for the 1-piece...87 was the first year for fi
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Also pre 80 blocks have the oil dip stick on the driver side and 80 on up it is the passenger side. 86 they went to the 1 piece rear main.
  7. roostr3269
    Jul 2, 2001
    305
    michigan
    Cool, thanx for the info, I will let him know.
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the "new" eninges also have the vortec heads that ahve different mainifold bolts, different valve cover bolts and (i think) use differnet headers.
    All this in additon to the differnt dipstick and 1 piece rear main.
  9. Re: My \'72 sbc 350 block the same as new ones?
    Although I have no idea when GM moved the motor mounts. They mounted either in front then moved to the middle or the middle then moved to the front. Not sure when though. Hope this helps. Later
  10. chevyboy24598
    chevyboy24598 1/2 ton status
    Jul 17, 2001
    212
    Va, USA
    The new blocks don't have a hole for a mechanical fuel pump. If you need some pics, I've got a 98 Vortec going in my 65 Chevy C10.
