My 88 has 30 splines axles but....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, May 25, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Everything I have read states that GM put 30 spline axles in 89-91 Blazers, Jimmys and Subs. I went to switch the shafts out of my 88 into the donor 85 front 10 bolt and couldn't get them to fit. Pulled them back out and counted the splines to find out they were 30 spline, not 28 spline like I had thought. Needless to say I was a lil /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
    Anybody else have an 88 that's like this?
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I pulled my 88 rear axle a couple weeks ago to see what I had. They were 28 spline too.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Who cares? The 30 spline shafts are rare and worth more money. /forums/images/graemlins/smile.gif Just sell them for two sets of 28s.
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    88's were mixed 28 and 30 spline. 89 they all went to 30 spline. If your front is 30 spline, then the rear most likely is, too.
  5. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    I like the idea of having 30 spline axles a whole lot better than 28, they are actully a little bit bigger. However, the gears that I need are in the 28 spline housing/axle.
  6. 88Silverado
    Mar 13, 2003
    2,664
    Hummm...I thought I saw something that said the stock carrier is a little weaker with 30 spline cuz they basically opened up the axle hole which weakened the carrier case. Most blown 10 bolts ive seen are the carriers or gears, not a broken axle.
  7. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    The crappy thing is, the 30 spline axles still neck down to the same thickness as a 28 spline, so there is no strength increase.
    Now, If you get a detroit carrier (Stronger than the stock one) and order the ORD 30 spline axles, you will have a strength increase over the same setup with 28 spline axles. Otherwise, no strength increase.
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    28 or 30 spline, its still a 10 bolt. /forums/images/graemlins/rotfl.gif
  9. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    yep switchin the spyda gears would most likely fix that mess, or sell'n the axles, i have two axles from a 10 bolt 30 spline rear axle, might try to trade\sell them for some 12 bolt axles for spairs, since i already have spair front axles for my front diff. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  10. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    In all honesty, you will prb WANT to go with the 28. They are just a little easier to find. Do you not have any 28 spline shafts? If you need some, let me know, I've got a spare set or 2 in my garage, I'm sure we could work something out /forums/images/graemlins/grin.gif
  11. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Well, I decided to put my existing frontend back in because the housing and axle itself was better looking than the one I was going to swap in. I will have to end up swapping gears anyway, so I will run 4.10's in the rear and see if I like it.
  12. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I have an '87 Suburban that has a 30 spline 10 bolt rear. I guess it could have been swapped in later, but there is no evidence that it was.
  13. Kyle89K5
    2,273
    OKLAHOMA
    I've already told you how I feel about 4.10's and 35"-36" tires /forums/images/graemlins/grin.gif but with the setup you've got now, you may feel like you're running 5.13's /forums/images/graemlins/grin.gif
  14. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Yeah, I'm gonna run this summer with 4.10's and if I don't like it then I will probably switch to 4.56's. A shop here in Tulsa called Young's 4wd is who I will go through, they are a really good shop.
  15. Kyle89K5
    2,273
    OKLAHOMA
    I won't be an ass about Young's cause Billy Ray is a nice guy, but check over their work. Sean is a REAL nice guy as well and is building a pretty slick rockwell RHD scout in there. I had a little trouble with them a few years ago, but nothing that keeps me from going in there and talking with them today. Unlike Sam's /forums/images/graemlins/angryfire.gif
    Good luck, let me know if you need any help, don't know how much help I could be, but I can be cheap hired help. I work for Pepsi /forums/images/graemlins/grin.gif
