My 91 454 vortec....dies....while hauling...UPDATE!!! THANKS CK5
Discussion in 'The Garage' started by JK5, Oct 20, 2004.
  1. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I was doing some towing with my 91 2500 with 454...
    I had driven amost an hour at about 65 mph..when..I noticed..my motor died..
    I hit the gas...nothing...
    Then...it back-fired..(almost blowing my exhaust off)
    After that...the truck sputtered..to my destination.
    The truck sat for 3 hours...
    it started...and ran fine..on the way home..
    but this time...I didn't go faster than 60..
    My question is...
    Do you guys think this may be fuel pump related???
    I'm NOT getting any DASH lights...
    and I changed my fuel filter a couple months ago.
    Jerry /forums/images/graemlins/cool.gif
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Re: My 91 454 vortec....dies....while hauling...HELP!!!
    Could be low fuel pressure. Usually though you would get a lean O2 sensor code.................................
  3. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I would say that the fuel pump isn't keeping up with the added demand of the towing.
  4. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    But the truck just dies..maybe no fuel pressure.
    I get NO engine light at all...
    kyser_soze
    That's what I had in mind...
    The truck does have over 250,000...
    It may be time for a fuel pump. /forums/images/graemlins/wink.gif
  5. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Could the coil or some part of the ignition system be getting overheated for some reason??????
  6. James670X
    James670X 1/2 ton status
    Nov 15, 2002
    122
    Calgary, Alberta, Canada
    Could be your fuel pressure regulator.
  7. dyeager535
    26,975
    So if it backfired, that means there was fuel being pumped into the cylinders, but it wasn't combusting.
  8. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Could the convertor be plugged?
    My thought also goes out to perhaps an ignition module?
    /forums/images/graemlins/dunno.gif
    John
  9. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I noticed...this morning...while going to work..
    It drives fine...until I give-it some gas..
    I hit about 80 mph...on the freeway...
    it wants to die...on the small hills...
    When I back down to 65....it stops...
    I should have pulled over to check the converter..
    to see if it's glowing..
    If it was a converter...
    I should get a engine light.
    I'm gonna check fuel pressure...
    and the regulator...
    I don't think it's an electrical problem...
    Because there seems to be power...
    The truck seems to be running outta gas...
    shutting the engine down.
    Thanks for your suggestions
    Jerry /forums/images/graemlins/peace.gif
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    My 89 did something similar to that and it was the coil and module in the disty..... But it was more of a sudden death than a sparatic thing.
    I'll ask my buddy Fred and see what he says...
  11. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Not necessairly. If the converter was plugged, it would also died when you came to a stop. Does it only do it when you hit bumps?
  12. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    No...just the slight hills...give me a problem.
    The truck never has come to a stop...
    it just shuts down for a second or 2..
    if I let up..on the gas..it goes away.. /forums/images/graemlins/dunno.gif
  13. diesel4me
    Jul 24, 2003
    17,540
    927
    Massachussetts
    Does it have a crank sensor? or a pick up coil in the distributor,or the module could be crapping out.The coil could be cracked or weak,causing weak spark that will fail under a load.You might have a bad ground also--wouldnt hurt to run a new ground wire from the engine to the negative battery terminal--my friends 92 caddy had a similar "stumble"under a load--moving the power seat switch could make it act up,so he decided to try a ground wire--its been fine ever since.
    I learned somthing yesterday anyone who own a jeep cherokee should know--after replacing the electric fuel pump in the tank of a 95 cherokee with a 4.0 six,it still wouldnt start--we had no voltage at the pump when testing with a test light--it had power before,so we assumed the fuel pump was shot,and changed it---we checked the wiring,fuses,relays etc.-everything checked out ok--after much research we learned the nuetral safty switch contols a LOT of things on a jeep--it has about 20 wires on it--the dealership said to check it by replacing it with a known good one-they said they replace a lot of them--went to the junkyard,got and tried another one--same deal--then a tech at the dealer said to replace the crank sensor--we were disbeleivers--thinking the crank sensor only sent a pulse to the distributor to tell it when to fire,but not on a jeep!--after we put in a new one,the fuel pump came on and it started right up!--seems jeeps wire the fuel pump curcuit through the crank sensor,so it it fails,you have no spark OR fuel pump!--drove is nuts for 2 days!. /forums/images/graemlins/angryfire.gif(P.S.--not sure but I think this only applies to jeeps,not any GM trucks). /forums/images/graemlins/crazy.gif
  14. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I just noticed...the engine ground isn't attached. /forums/images/graemlins/doah.gif
    I take care of that...and do some more checking..
    Thanks...for Your Help guys... /forums/images/graemlins/peace.gif
  15. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    Do it again, or at least check it by shaking out the inlet side over a clean rag and see what comes out. But if you have it off you may as well put a new one on.
  16. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    If the crank sensor doesnt work, nothing will.
  17. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    After checking all of the above...
    I found...a couple loose grounds..and a dirty fuel filter.
    I hauled my rig over 3 hours without a glitch...saturday.
    I'm headed to Wellsville this saturday...
    That will be a good test!!! /forums/images/graemlins/wink.gif
  18. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    My 88 1-ton did the same thing and the cat was clogged big time! It would not do it though until it got to normal op temp....
