My 91 got a lean engine code, where should i start??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CiceroK5, Jul 15, 2003.
  1. CiceroK5
    CiceroK5 Registered Member
    Jan 14, 2003
    41
    Lake Bluff, Il
    Where should start checking. Is it an injector or fuel pump issue? What regulates how muc fuel she gets. I had a tune up 2 months ago and a whole new exhaust put on, high flow cat to magnaflow muffler and duals back, no headers. and a new o2 sensor? I hve about 129k on the truck, WTF!!!!!!
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif You never replied to your last post . /forums/images/graemlins/rolleyes.gif
    Did you start getting the check engine light after the tune-up or after the new exhaust?
  3. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Check to make sure your EGR is working properly, and also remove it and make sure the passage in the intake is not clogged. Then make sure the EGR solenoid is working properly. After that i'd say O2 (they are only 15 bucks if you have the one wire one) Let us know how the chechs work out.
  4. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Make sure there are no exhaust leaks upstream of the O2 sensor, or near it for that matter. If exhaust is leaking out fresh air can get in and give a false lean signal to the O2 sensor.
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    check your fuel pressure...if it is too low, you will get a lean conditon...also, does the light come on at idle or at part throttle or WOT. I would get a scanner or download WinALDL to see what the O2 is reading at different RPM...
