My Bazer won't turn off!!!! Help!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazincajun, Sep 10, 2002.
  1. blazincajun
    blazincajun Registered Member
    Sep 6, 2002
    5
    My Bazer won\'t turn off!!!! Help!!!
    Finally got all the lights working on my 75 k5 but for some reason when I turn the key off, the truck keeps running... It's pretty scary not being able to turn off my truck, anybody ever see the movie maximum overdrive? Any help will be greatly appreciated.
    Thanks,
    Brandon
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Re: My Bazer won\'t turn off!!!! Help!!!
    is it outta gas yet???
    LOL
    Does it actually just keep running or does it sputter and sputte then die...
  3. Storm Trooper
    Nov 24, 2000
    4,640
    Can you pull some fuses or disconect the electic to the coil?
    Sound like you have a bad ingintion switch or a sort in the wire to the ignition switch that is keeping the power to the run curcuit. Oh....and are you out of gas yet?
  4. camarine
    camarine Registered Member
    May 27, 2002
    78
    NC
    Had the same problem Monday and I tried replacing the switc. What I ended up doing was cleaning the connectors going to the starter and it fixed everything. Now all I have to do is to rewire the starter. Remember to start where all of the power is coming from then work your way back. /forums/images/icons/confused.gif
