My brakes are gonna give me a brain hemmorige (sp?)
Discussion in 'The Garage' started by Silver84k5, Feb 19, 2004.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i drove it last night after i put new shows, and springs in the drums, replaced the drivers side brake cylinder, ive replaced the booster, i think i did the master cylinder, and i still have no rear brakes, and when i press the pedal slowly itll go way too far down, then if i have it in drive and press it slow itll go almost to the floor, then if i hold it there and put it neutral itll come back out a little bit..... What else should i try? Take to a brake shop and have them bleed it? Proportioning valve?
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    are your rear brake shoes adjusted up so there is slight drag when turning by hand? /forums/images/graemlins/dunno.gif
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    When it goes to the floor,,,can you pump it back up? hit the pedal a few times, does it come back up or does it stay down?
  4. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    ok i adjusted them so they are touching, but i figure since it is self adjusting that it would just take care of itself..
  5. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    did that help the pedal? They will self adjust when backing and braking enough to compensate for brake wear but not enough for un adjusted brakes.
  6. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    hey thats how my brakes are now. i lifted mine in the air and in drive withe the brake pedal to the floor it barley stops them from spinning.
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    well i guess ill try adjusting when i get home...
  8. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    sometimes they are so far out of adjustment that it can cause your problem, its the next step anyway. after you adjust press on the brake pedal a few times and check adjustment again to make sure the shoes are seated before you let the jack down. good luck /forums/images/graemlins/thumb.gif
  9. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    do you know how much pressure should be released when the back brakes are bled? the pedal doesnt go to the floor. and it seems to just dribble out..... does that tell you anything?
  10. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    you should get a good steady stream, it tells me your brake shoes could be so far out of adjustment that the master cylinder cycles fully before the shoes finally contact the drum. also could be air trapped somewhere or the master cylinder not holding pressure. you gotta adjust the rear brakes as your next step.
  11. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    or the wheel cylinder leaking or seized......
  12. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    if the adjustment doesnt work, how do i check/bleed, the air out of the Master Cylinder?
  13. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    you can bleed it just like a wheel cylinder just use the brake line fitting to let the air out, sometimes air will get trapped at the fittings.
  14. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    if the brakes were to far out one of the pushers (?) on the ends of the wheel cylinders may have popped out. check them and nake sure your not getting air in there.
    69k5
  15. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Did you bench bleed the master cylinder before installing it?
  16. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    come to think of it i didnt replace the MC, cuz i never bench bled anything.
  17. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    dude.....the condition you are describing is a typical master cylinder failure but I assumed you already replaced it!! adjust your rear brakes and replace the master cylinder if it wont create any pressure. /forums/images/graemlins/dunno.gif
  18. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    hah k.... ill give it a shot... i thought when the master cylinder went out, It WENT OUT... but my brakes have been like this for like 8 months.
