My build up79 blazer to a 70 cab
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by jays68yak, Feb 27, 2006.
  1. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    Well I guess I should start posting on this side of the board. I got tired of my blazer so I decided to drop a 70 cab onto the blazer frame and running gear. Its going to have the front sheetmetal but its going to be tapered 7 inches on each side. The cab is getting the 79 blazer tilt column, wiring harness, and hydroboost setup. Going to graft that part of the firewall onto the 70 cab.
    Heres a few pics of the progress over the weekend.
    Body Swap Day 1
    10am
    A shot of the 63" springs installed
    11am
    Noon
    1pm
    2-3pm
    Heres a pic of it sitting on the frame. No body mounts are installed in this picture. I do now have the front 2 bolted onto the frame. I need to figure out the rear ones as the bolts are only 1/2" from the side of the frame.
  2. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    What are you going to do about a bed? Tube???
  3. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    Tube bed much like crwln73's current one. Maybe skin it, maybe not. I dunno havnt made up my mind.
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Get R Done Bonzi!
    YYYYYYYYYEEEEEEEEEEEHHHHHHHHHHHHHHAAAAAAAAAAAAAA!!
    :D
  5. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Will enjoy watching this progress - looks like a great project.
  6. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    Ok all four body mounts are done for the most part. I need to weld up the rear ones where I added some 3/16" metal since I had to move the hole 1.25" out from the stock ones.
    I also started on the firewall/steering column/brakebooster. In talking the swap over with my buddy Kevin, he had mentioned grafting the blazer firewall onto the cab. Looking at the two I decided to drill out the spot welds on the steering column/brakebooster brace that was on the blazer tub. There are a good 15 spot welds that I had to drill out. I plan on just respot welding it onto the cabs firewall.
    Here it is all mocked up. I need to find the piece that goes under that dash to hold the column up.
  7. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Nice work.
    I'm gonna watch this one...:bow:
  8. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    your not the only one i have a 90 k5 and a 68 cab
  9. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    Got any pics of yours?
  10. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    i havent started mine yet im gonna wait and see if the body is gonna hold long story
  11. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Any more progress?
  12. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    I got some lights mounted in my garage so that I can work at night. :D Progress has been slow mostly due to being lazy. Saturday I spent a few hours cutting up the bed that was on the truck that I got the cab from. Going to use the bed sides to skin the tube bed. Sunday was spent riding shotgun in my buddys sammi. I did manage to get my 203 torn apart. I guess I am going to go with a doubler. I just need to figure out if I can fork over the money for a doubler kit or if Im going to try and fab my own.
  13. 4bynut
    4bynut 1/2 ton status
    Sep 21, 2004
    675
    Morrison, IL
    Wish I could see the pics!! All I get is red X's.:confused: :(
  14. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
  15. jaros44
    jaros44 1/2 ton status
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Radiator Support
    If you are not going to use the radiator support mount from the front clip I would be willing to buy it from you, Mine is pretty thin from all the years of battery acid dripping on it. Those rivets are pretty hard to get out so maybe you could just torch the frame rail
    Nice work so far on your project, enjoy following your progress. Later J.
  16. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    The ones currently on the blazer frame are also supporting the spring hangers.
    The ones from the frame that donated the cab are gone as I cut up the frame and tossed it 2 weeks ago.
  17. jaros44
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Thanks anyway it was worth a try, I'll try elsewhere
  18. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    Ok finally a decent update. Got the brake booster mounted up yesterday. Also got the harness mounted and the bulkhead througth the firewall.
    Today Im playing with the hood. So far I think I have about 3 hours into the one side of the hood. :eek1: Cutting takes forever. Iv been using a pneumatic cut off wheel. I think im going to try the sawzall on the other side.
  19. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    wishin you had a plasma cutter huh! me too. i wish i'd just hook the damn thing up and start workin it.:doah: but at least the oxy/acy works.
  20. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    Ok While I wait for tech support from my hosting co to get back to me...:mad: I uploaded the pics to my gallery here on ck5. Here are the latest updateds. Last night I chopped off the front bumper. It will get rebuilt to look cooler and fuction better. Oh and have some tow points on it. :doah:I ditched the rad support in favor of some tube. Now I just need to get the bender mounted and buy some tube.
