My cab is finally back on the frame
Discussion in 'The Garage' started by Yukon Jack, Jul 2, 2004.
  1. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    After way too many months, my cab is finally back on the frame! At some point I will get to fire up the 454 - can't wait!
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    wow that looks good. /forums/images/graemlins/peace.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    When ya get time, fix that shackle angle up front, it's free. /forums/images/graemlins/thumb.gif
  4. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    What's wrong with the shackle angle and how do I fix it for free? /forums/images/graemlins/dunno.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  6. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    So it should be like \ rather than / ?
    I wonder why it is that way, it is a correct sized spring for a 69. Interesting.
    Okay, looked at yours. The previous lift springs were also positioned this way. Very odd. That will have to be on a todo list in the future cause I am eager to stop modifying and start reassemblying and getting to enjoy this truck for a while, it has been torn apart since October of 2002.
  7. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    I would think that once the engine, trans,t-case, doors ect...ect...ect..are installed that angle will be greatly improved.
    By the way It looks bad azz /forums/images/graemlins/pimp1.gif
  8. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I'm pretty sure all lift springs pull your shackle foreward like that. The companies that make them all use the stock dimensions for the spring's "eye to eye" when they should add a few inches. It looks like you've got ORD shackles, you'll need to make your own if you move the shackle mount because it will move upwards in your frame causing the shackle to be too short. I'd leave it the way it is since you're adding a big block to that truck and that should help get the shackle close to where it needs to be. Just my $.02
  9. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    The big block is sitting in the frame so all that will change weight wise is the front clip and interior.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It is that way because the stock springs are negative arch. Nobody at the lift kit companies had enough brains to realize that the shackle angle would be backwards for positive arch springs and as a result we all have crappy shackle angle in stock form.
    I noticed that before I mentioned this in the first place. If that was your shackle angle with no motor it probably wouldn't be so bad. having that be your shackle angle with the engine installed makes it terrible.
    It took me a morning to do it but it was well worth it for the increase in flex (especially droop) and better ride quality.
