My CamShaft TOO BIG?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82Jimmy, Sep 5, 2000.
  1. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    I got a comp cams .280 in .280 out...is it just too big?
    <font color=blue>If its too loud, your too old.</font color=blue>
    http://82Jimmy.coloradok5.com
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Only if you want power only above 4000rpms, crappy idle and the need to buy a new higher-stall torque converter.
    If you want low-end power, you should look into a cam with about 204-210 deg of intake duration @.050 lift.
    If you're talking about advertised duration, then it could work, although pretty high still.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  3. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    you'll pull a stud unless you have matched components in the heads
    Theres No Replacement for Cubic Inches!
