My cap wont go onto the distributor...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Dec 3, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I cant get my cap on.. the firewall is in the way...
    Damn body lifts...
    I'm gonna go buy a sawzall... :d
    Cut the firewall up I guess... /forums/images/graemlins/confused.gif
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Was is hitting before? I wouldn't think a body lift would cause this problem, how about a bad motor mount or t-case mount? Have you done anything else to it that might have caused this (drop t-case, etc.)?
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    What he said, i was thinking the same thing, cause when I put my body lift on, it actually gave me more clearance for the cap install and removal.
  4. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    lol, how far is it off?? i'd try hitting it with a hammer, and see if that gives you enough room? that's what most people do (if they need the room), that convert from points to hei.
  5. reddog64
    Nov 9, 2000
    3,325
    well the bodylift and dropping the t-case caused the rotor cap to align perfectly with teh lip on the bottom of the firewall... I tried the hammer approace... I just cut about 1 inch outta it... works fine now... /forums/images/graemlins/smile.gif
    Now I'm 180 out.... motor just backfires through carb /forums/images/graemlins/angryfire.gif
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well the body lift didn't do much except line up the lip but when you droped your Tcase, you tilted the engine backwards into the firewall.
    That is why I don't like that aproach.
    If going with more than a 3" suspension lift I go with a different driveshaft, either clearanced or high angle.
  7. reddog64
    Nov 9, 2000
    3,325
    I had mine lengthened and I lowered the tcase to help the angle of my 6 inch lift... keep in mind a blazers shaft is already short.... and a high lift doesnt help..... every angle you can gain back helps...
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    You forget that lowering your tcase increases the angle on the front shaft which is even shorter than the rear.
    I know it's not a full time use but it still will make it harder on the front shaft.
  9. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Good point /forums/images/graemlins/thumb.gif Not to mention, just think of what it does to your motor mounts. I mean if everything is bolted up solidly and you drop your t-case, that just cranks down on the motor mounts.
    I got away easy...when I lifted my /forums/images/graemlins/burb.gif 4" I didn't have to get new shafts, or drop the t-case. (Thank you long driveshafts) /forums/images/graemlins/smile.gif
  10. reddog64
    Nov 9, 2000
    3,325
    YEAH...
    When I get teh new shaft from jessie, I'll raise it back to stuck height...
    But that's 350 away... /forums/images/graemlins/confused.gif
