my carb!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Mar 6, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    ok...choke is unplugged, k&n filter...edlebrock 600 carb
    its not idling, unles you punch it or let it sit it wont idle...so i made appt to have i adjusted tomorrow...i drive home from work, turn it off...it goes "purt purt purt pfffffft"...like some kind of pressure was let off
    asked a friend and they said soudned like it backfired through the carb
    prob is...i cant start it to take the mfer back
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Check the timming. [ QUOTE ]
  3. Hektyk
    Hektyk Registered Member
    Feb 4, 2003
    51
    DFW TEXAS
    Yup definetly sounds like you need to turn your timeing up a little.
  4. 4DiggerDan
    4DiggerDan 1/2 ton status
    Feb 2, 2003
    103
    Montucky, USA
    I just went through something similar... Except mine all of a sudden sounded like the truck was running under water. I tore the Carter EGR carb that was on there OFF... Then I stuck those jets and metering rods into another Edelbrock that I was saving for my Blazer build up (gotta run a carb until I can afford a fuelie system.)
    Problem solved /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    Except now I'm playing the "Bend the choke rod to adjust mixture at idle right after startup game." You know the one. After you fire up your truck it runs fine until your ass gets off the seat to go back in the house where there's a warm cup of coffee waiting for you, then it starts running like crap and blowing black smoke until you put your ass back on the seat and give it more gas.... /forums/images/graemlins/confused.gif
    I decided that I need to try out one of the new Edelbrock offroad AVS carbs on my 383. Of course I'll let you all know how it works out.
  5. tecton
    Dec 1, 2002
    1,553
    WV
    ---------UPDATE-----------
    MFer at advance gave me the wrong size filter...put on the old one and problem solved...taking that [censored] back in the morning and having the carb tuned also...
    i was pissed too
