my d60 looks like it will leak? *pics*
Discussion in 'The Garage' started by BranndonC, Dec 15, 2003.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    after installing the locker required me pulling the shaft out 6 inches, when i put it back i noticed a gap that looks like fluid would pour out of it not to mention stuff getting in.. is this normal or is something wrong?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    the axle seal is further inboard in the tube..i think thats more to trap large debris from entering..
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    so thats normal then, no big deal?
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    dont worry about it, just ship it on over here and ill test it for about 50 yrs and tell ya how it works, aw what the heck im such a sport ill even pay shipping.
  5. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    [/ QUOTE ]Yep,The seal" is further down the tube
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks everyone /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
  7. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Branddon, Do you have to set the contact patteren after you put the gears back in?
  8. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    nope, from what i've found by searching and through the instructions no its not required. so i hope thats right /forums/images/graemlins/ignore.gif because i didnt set anything when i reinstalled them /forums/images/graemlins/eek.gif /forums/images/graemlins/thinking.gif
  9. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    /forums/images/graemlins/rolleyes.gif
  10. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    yep the seal is at the diff, I pulled my out sandblasted and painted them... /forums/images/graemlins/thumb.gif
  11. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I figured i would ask,did not know if you needed to or not.If you find out you do check precisiongear.com they have the info on setting contact patterns in the tech section.....
  12. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    /forums/images/graemlins/confused.gif
  13. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    On dana 60's 44's and any bearing cap design (not like a 14FF) you just have to keep the same bearings on the carrier and leave the shims in the same order on the same sides as it came. It is that easy.
    oh and the seal is in the tube farther. It can leak if you gouged it with the axle thuogh (I did this so don't fell alone if it happens)
  14. keith
    1,158
    La Fayette, GA
    I just figure a guy with 2309 posts would know this stuff. /forums/images/graemlins/rotfl.gif
  15. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    post count doesnt matter all that much IMO... if i never owned, saw or touched a d60 before, how would i know about them? i did do a search but with such a wierd description i didnt have much luck. Before my truck i never even touched a wrench before so this is ALL new to me so i can only learn as i go. i dont know what you know about rockwells or uni mogs, but youve been bere almost 4 years now and that doesnt make you an expert in every field though
  16. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    I just look at post counting as the number of new things learned. If you came in here as a clean hand rookie and now have 2500+ posts you are probably about the median as far as wrenching knowledge goes. I have moderate to good expierience wrenching and still have learned about a 150 new things (my post count /forums/images/graemlins/grin.gif)
    That is all (said like a school principle)
  17. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Brandon,
    Something looks weird with that pic? Is that inner axle ALL the way in, with the outer kunckle/rotor/hub installed?
    It looks like it's sticking out about 1" too much for some reason....
    Damn, now I'm going to have to go outside and look at MINE! /forums/images/graemlins/grin.gif
    .....Ok, I'm back...I wasn't kidding I went outside and took this pic with a flashlight:
    See how much DEEPER the inner axle sits in this pic? Also, there IS a sort of scraper/seal on the back edge of the inner axleshaft that is there to keep the major crap out of the tube... once it's installed things will look more "correct"! /forums/images/graemlins/thumb.gif
  18. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    yeah it slid in and out, and i didnt know weather to shove it all the way in or not.. i'll go slide it in tomorrow morning /forums/images/graemlins/thumb.gif thanks
  19. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    it should be "shoved" in more, did you put together the outers yet? i dont see how the spindle would fit right witht he outer shaft being so far out.
  20. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    yup i put it together and everything fit fine
