My Day isn't getting any better
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Aug 20, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    My Day isn\'t getting any better
    i spent all day today replacing my oil pan gasket in hopes to stop my oil leak, and i did various other tasks like hooking up my driveshaft and torque converter to the flywheel. Well i start it up and guess wat, the oil is still leaking, and this time its even worse. It looks as if its coming from tranny and somehow spraying itself everywhere so that oil can somehow drip onto my exhaust manifol from the firewall. the only hint i have its from the tranny is that the oil is dripping onto the ground from the tranny fluid pan. Any help would be appreciated.
    phill
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Re: My Day isn\'t getting any better
    My first suggestion would be to determine if your leaking oil or tranny fluid. If it's tranny fluid it's probably your pump seal. If it's oil and coming from the back, bottom of your motor I would guess rear main seal. My oil leak was coming from the front....timing chain was so loose it rubbed a hole in the timing chain cover!!! Good luck!
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  3. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    My oil leak was coming from the back of the valve covers. Tightened down and it was all gone.....
    On your oil pan gasket, did you go back and forth, side to side and front to back as you were tightening it down?
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    yeah...did you torque all the oil pan bolts to spec? Believe me it makes a difference
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
    1982 Chevy C-10 Longbed
  5. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    man, have you been taking bad luck lesson's from me??? [​IMG]
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  6. shupach
    Dec 28, 2000
    648
    Dallas, TX
    now that u mention it, it could be the back of the valve covers. uhm, torque to spec?? i just made sure they were really tight? and im positive its not tranny fluid. Im tempted to take the engine, tranny and tcase all out, do a top end rebuild on the engine and get a new tranny and tcase. and when i say top end rebuild i mean everything except the pistons and crank.
    phill
  7. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    If it is spraying around it could be the front pump, now it could be your tranny coolant lines if their not tight.
    Good luck and let us know what you find. Eric
    I just saw that you know it's not tranny fluid. as for thr eng. oil it could be valve covers, oil presser line , distributor gasget.
    have fun.
    &lt;a target="_blank" href=http://cethern.tripod.com/erics-home-page-and-other-stuff/&gt;http://cethern.tripod.com/erics-home-page-and-other-stuff/&lt;/a&gt;
    AMSOIL Dealer # 529948
    &lt;a href="mailto:Cethern@interfold.com"&gt;Cethern@interfold.com&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by Highlander on 08/20/01 07:11 PM.</FONT></P>
  8. shupach
    Dec 28, 2000
    648
    Dallas, TX
    its either the oil pressure line or the valve covers, i also think its the cooler lines for the tranny but i thought those contained ATF and not oil.
    phill
  9. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Double check you oil sender/pressure unit. Mine leaked like a hose for awhile and I thought it was my rear main seal.
  10. shupach
    Dec 28, 2000
    648
    Dallas, TX
    mine isn't hooked up, i just put a bolt in there but i guess that could be a problem.
    phill
  11. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Spray some brakleene up there and clean the area of. And see if it gives you that black dribble. May try it to see if it works or gets worse with the engine on.
  12. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    When I said the tranny that was before you said that it wasn't ATF. One time I forgot to put a gasget under the dist. and that thing leaked really good. Have you cleaned the motor up good then start it. It would give you a fresh look at the leak.
    <a target="_blank" href=http://cethern.tripod.com/erics-home-page-and-other-stuff/>http://cethern.tripod.com/erics-home-page-and-other-stuff/</a>
  13. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    i'm guessing the rear main seal too. Found out mine was bad today when the tranny shop took the tranny out, and it sounds like the problem is in that area.
    90K5
  14. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    You said ypou made sure the bolts were really tight? Now you may have warped the pan by overtightening the bolts. Especially if youre using a cork gastet.
  15. shupach
    Dec 28, 2000
    648
    Dallas, TX
    nope, i spent the extra 20 bux and got me a rubber gasket. rear main seal, isnt that the back park of the oil pan, cause if it is i just replaced that. and if that isnt it i just rebuilt the engine so im positive that cant be it.
  16. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    i had the same thing check the oil filter or it may be the pan is bent alittle bring it to a tranny shop an tell them its slipin an they will take the pan off after a test drive i did that an they gave me a new trany filter screen an that was it heheheh
    can some 1 find me a ford i need to take a pee still peein on that ford just have to keep goin dam i can not stop pissin:) k5s kings
