My death wobble issues resolved
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Derf00, May 31, 2003.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Last fall I started having at times a bad case of dw on my 60. I had run it a little over a year before dw showed up. I read everything I could find on CK5 & PBB, and then looked at several things that are supposed to cause problems. I was unwilling to just throw money at the problem and hope I got lucky.
    With or without the dw I was planning on going to the Redneck Ram, so I purchased it a little sooner than planned, but it solved the problem. Yes, this was an expensive band-aid.
    In a reply to one of the posts I had made about the dw, Tim of 4x4 Iron made a post about how he had added a 1/4" washer on top of the spring that sits on top of the kingpin bushing, to increase the pre-load on the bushing.
    Last night I replace a broken kingpin bushing, spring, and retaining washer. Before replacing the spring, I compaired it to the new one. As you can see, there is quite a difference.
    Just out of curiosity, I disconnected the ram, and took a quick trip to a stretch of road that always produced dw. I am happy to report, it is gone. [​IMG]
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Glad you got it cased. /forums/images/graemlins/thumb.gif
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    looks like a 1/4 inch... /forums/images/graemlins/thumb.gif
  4. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    what is the height of the new spring? about 2 1/4" ? I can't quite make it out in the picture. Glad to hear that solved it.
  5. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    2 5/16"
  6. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
  7. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    you are awesome /forums/images/graemlins/grin.gif i remember hearing about springs causing it....and now i know. how much were the springs and where can i get some?? thanx a lot
    NITRO
  8. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Springs - GM part # 00462799 - $10.86 ea
    Retainer- GM part # 00475504 - $ 2.85 ea
    Bushing - GM part # 15536433 - $6.00 ea(about)
    Results - priceless /forums/images/graemlins/grin.gif
  9. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    good to know. now i wish i didnt have mine al put back together. guess ill just mearure one spring when i put the x-over on. i replaced EVERYTHING else in the dang thing. dont know why i didnt the springs.
    did you post those part numbers in the part numbers post?
    Grant
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Hey derf00, just thought I would point out you have the same part number listed for the spring and the bushing. Was going to get these numbers to a friend and noticed that.
  11. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Those parts are expensive through GM. Buy them from spicer.
    -- Mike
  12. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Randy's Ring and Pinion can sell you a "knuckle kit" also, for something like $80/side. It includes everything above, plus seals and the spindle bearing too IIRC.
    -Dan
  13. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    Parts Mike also sells them king pin rebuild kits for $89 for BOTH sides. www.partmikeparts.com Later
    -fLeXy K20
