my drive shaft magically grew!
Discussion in 'The Garage' started by BranndonC, May 2, 2004.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i dont know how, but after my last trip i noticed i have NO play in my drive shaft's slip yolk. i mean i slide it on the out put shaft of the 241 and it slides all the way on and i still have to wiggle it and remove the u-joint caps just to get it installed, what coulda caused this? its a newly re-manned t-case also. /forums/images/graemlins/dunno.gif i'll take pics tomorrow if that will help /forums/images/graemlins/confused.gif
  2. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Maybe your truck saw a female Blazer and that's what made its shaft grow longer /forums/images/graemlins/histerical.gif
    How do you tell what gender a truck is? All of mine are "girls", but that's like the Navy... even boats named after presidents are called "her."
    -- A
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I bet your shaft is too long, call Jess and see if he can get you the measurements that its supposed to be and see if yours is too long for your app.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Did you haul anything heavy lately? Maybe your springs are sagging. /forums/images/graemlins/dunno.gif
  5. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I think trucks are definitely guys, even more. They have 2 shafts, and 2 rods on either end with big balls in the center. /forums/images/graemlins/peace.gif
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    yeah i hauled 500-800 lbs recently and wheeled on some rocks with it in the rear, i dont think that little weight would make the stock springs sag though.
    and jason, how would it grow, thats the problem, it was the correct length when i bought it /forums/images/graemlins/eek.gif
  7. zcarczar
    Feb 10, 2002
    2,495
    hmmm maybe try lubing the splines to see if it slides ok
  8. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    there lubricated, it slides smooth, but i know its fully inserted, i'll pull it this week and see if anything wierd stands out.
  9. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    The only thing that will cause this is sagging springs. When you measured for the correct length driveshaft did you maybe have the truck off the ground then put it back down and not rolled it back and forth to settle the springs first and now that gave you a false measurement?
  10. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Family site reminder! /forums/images/graemlins/shame.gif /forums/images/graemlins/doah.gif
    Exactly what are you talking about here? /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  11. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Have you checked that your rear axle didn't move forward. Maybe the centering pins broke and you axle moved forward? How short are we talking about? ANd just out of curiosity, why did you have the shaft out? Anything that may have cause things to shift? /forums/images/graemlins/dunno.gif
  12. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Hey Brandon
    I like Esteban's Idea about the rear axle
    but i also gotta ask
    as you said the tranny was recently worked on
    3possiobility
    1 the bell housing is broke and your trannny - t case adpter and Torque converter is the only thing holding it togeteher
    Is your Factory T case torque rod still connected ??
    2 your adapter is broke ( very unlikly if no leaks )
    3 the tranny shop changed adapters on ya or didnt lower the t case or lowered it and it previsouly wasnt
    4. this 1 is a long s shot but they put a 208 in instead of a 241 ?? as if i rember correctly the 208 is a little longer then the 241
    well when ya figure it out let us know
    I know I am curious
    R
  13. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I thought mine grew too but it was just morning wood.. /forums/images/graemlins/rotfl.gif
  14. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks doc, but it was my t-case that was re-manufactured, not the tranny, and i installed it my self, so i know its the 214, i'll check on the rear axle and see if it moved any. Thanks for all the ideas!
