My driveline degree angles....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, Jun 2, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I got the angles my rear driveline is at:
    78* at the diff and 85* at the t-case.
    The specs:
    6" lift
    36" tires
    front springs, shackle flip rear and ORD add-a-leaf
    Would I be able to get away with shimming the rear axle? If so, how much, 4-6*? Also, the front shaft is really at a severe angle. Can you shim the front also, or...?
    I figured I would have to get my rear shaft lenghtened but it appears that I will not have to. It actually slides into the t-case farther than when it was stock.
    Ross
  2. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Anybody?
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    You want the degrees within 2 to 4 of each other so either the 4* or 6* shims would work with 6* being the one that will make the u joint most happy. the front shoudl have a cv style shaft and on that you want to point the pinion at the t case output. (most lifts call for a 3 or 4 degree in the front) My trailmaster kti came with a 2.5* shim and my buddies 6" came with the angle already in the pack.
    -Jeremy
