My Drums are weird. HELP!!
Discussion in 'The Garage' started by k5freak44, Mar 16, 2005.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    14bff drums. cant get em off.
    they are loose and i can move them back and forth about.... a half inch.
    all the spindle nuts are off and i cant find an acess hole in the back
    i do have a liuttle brass pin that has a sping on it and when i try to pry it off the drums move. im assumeing this is my problem but it has no way of grabbing it or removing it that i can see. here is a pic
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    that thing holds the brake shoes on, I had one break, fun stuff. Are you sure there isnt a ridge inside the drums the shoes are stuck in. Try backin the shoes off, and itll prob pop right off.
  3. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    how do i back the shoes off? i dont have that little access pannel
  4. blaznjon
    blaznjon 1/2 ton status
    Mar 6, 2004
    153
    Seaside CA.
    Your brake shoes are probably stuck in a groove they wor into the drums.You are going to need to backoff the adjusters.There should be a knockout in the front of the drum,that you can knock in with a chisel.You should be able to get o the adjuster thru that hole. The little brass thing is the hold down pin,that holds a spring that holds your shoes to the backing plate.Jon
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it may be in the drum and not on the backingplate.
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    see that long skinny hole at the top of the pic? Thats the sighting hole. There should be another opposite on the backing plate. In between there should be either, a flat metal piece like a plug, a rubber plug, or a punchout. If its a punchout, you will have to knock it inside the drum, back the shoes off, and then remove the drum & the metal piece.
    Behind that plug of punchout will be a star wheel w/ a metal piece that keeps it from backing off. I use 2 long skinny screwdrivers, one pushin away on the metal piece, and the other backin the shoes off. They make a special tool for it, but it aint that hard w/ 2 screwdrivers
  7. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    alright i found it after a couple of minutes of strategically placeing my flashliught and turning my drum. i dont know if its maxed out or frozen tho, but when i try to turn it with my screwdriver it just twists the whole line then pops back and dosent spin it anywhere.
    im not sure if this is my problem tho.
    if the pads were grooved into the drums, would it allow about a .5in movement of the drum. i can also easily spin my drums.
    it looks like the pad is in contact with them tho.
    ahhhh i dunno im done for tonight i have a bunch of homework.
    help!!!!!
    thanks guys
  8. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    had the sort of the same problem last week. the e-brake was locked in and the adjuster nut was striped. so I used and prybar and kept prying it open between the drum and backing plate. I destroyed the shoes and the e brake assambley but I wasn't going to reuse them since I was going to disk brakes anyways. o yeah I used the BFH too it took awhile but I got them off.
  9. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Bigger hammer, seriously. Whack them enough times they'll come out even if the shoes are holding them in.
  10. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    ive been wacking aroud the edge of the drum with a hammer. is there a better place to hit it?
    will the reguar sized hammer im useing work?
  11. AkMudr
    Dec 30, 2004
    917
    Alaska
    Whack, rotate, whack, rotate. You could try cracking the bleeder to let off any pressure in the system. The shoes will retract as you beat the drum out.
  12. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    k
    thanks ill try that tomarro
  13. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    If you were just gonna swap to rear disc's you could have unbolted the backing plate and removed the whole works in under 5 minutes...;)
    Rene
  14. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    ummmm.... but the bolt were from the inside. unless I was missing somthing :thinking:
  15. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    yea thats what i was thinking
  16. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    Unless you're using the Force, you still need to remove the drum to get at the backing plate bolts;)
    As for the original post, I can only repeat the above suggestions: penetrating fluid, backing off the star wheel adjuster (I never know which way to turn the damn thing), brute force and/or some heat:( .
    James
  17. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    LOL, it's been a few years since I had drums...:doah:
    Rene
  18. AkMudr
    Dec 30, 2004
    917
    Alaska
    IIRC trhe adjuster wheel only can be tightened not loosened becuase the parking brake lever rests on it and locks it in place. You'd hafta push the parking brake lever out of the way in order to loosen it up. Or I oculd be all wrong :grin:
  19. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    That's the reason for the second screwdriver. One to push the lever away from the adjuster, and one to turn the adjuster.
    Rene
  20. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Just had a thought. You might be able to twist and undo the shoe retainers from the back side with some good pliers...
    Rene
