My e-brake cable is different!!!
Discussion in 'The Garage' started by TruckNutzDude, Aug 6, 2003.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I was going to swap to discs and I will, just not today. But now that I've decided to keep the drums temporarily I noticed my e-brake cable is totally different from the K20 14 bolt to my 1990 10 bolt. The '79 K20 axle has a sandwich plate style e-brake mount (to the backing plate) where my 10 bolt has the typical hole and tang style. What do I need to do to make this swap work???? Will I need to make a bracket or should I just buy some K20 cables? /forums/images/graemlins/confused.gif
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Re: Did search and still need information (about my disc brake conversion)
    Hmmm Rear Disk brakes.....I love mine DO IT /forums/images/graemlins/thumb.gif I am not sure about the ABS. I cant imagine it is too hard to get around it. For wheel studs just use Autozone part # 98739. 9/16x3" should be the same for all of the 14bff. They are 2.59 a piece and all the autozones I went to only carried 5 of them so you may need to hit a couple of different stores. Here is my setup.
  3. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Nice setup, but where's all the rust? /forums/images/graemlins/rolleyes.gif That's exactly what I'd like to do, only I need an e-brake to be legal in MA. /forums/images/graemlins/blush.gif
  4. LUBA
    LUBA 1/2 ton status
    Jan 16, 2002
    127
    Bay City, Michigan 48708
    I got a set of caddy calipers minus the springs and levers. $60 plus shipping if your interested. I just bought them for the springs/levers never used them so they might just be good for cores not sure though. Cores are $$$!
  5. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I might be interested, I'll let you know by this weekend. Thanks for posting /forums/images/graemlins/smile.gif
  6. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I decided to recycle this post about my disc brake swap to keep the # of posts in the garage to a minimum! I figured I'd mention that incase someone was wondering why the top post doesn't make much sense /forums/images/graemlins/grin.gif
  7. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Check here:
    http://coloradok5.com/forums/showflat.php?Cat=&Board=blazer4x4&Number=627643&Forum=All_Forums&Words=14FF%20e-brake%20cable&Match=And&Searchpage=0&Limit=100&Old=allposts&Main=625283&Search=true#Post627643
    I think the newer 14FF cables will work along with a quick mod on the bracket.
    You might even be able to "bubble gum" something together with air-craft cable from the hardware store and some crimp clamps (don't know how much the DMV would like it though).
