My engine bay wiring is a mess
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DukeBoy88, Apr 23, 2003.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    I tried a search but didn't find what I was looking for. I'd like to reroute my wiring and organise it better. I also found 2 disconnected wires in the loom that I haven't figured out what they go to yet. I may use wire looms again unless there is something else out there, but I'd like to relocate the wiring that wraps behind the distributor higher on the firewall as well as secure other wiring out of harms way. also thought of relocating my msd and coil inside the cab. anyone have pictures of what they did? looking for ideas. thanks in advance.
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    I just use conduit and attach it to stuff every so often using clips or zip ties. In the case of big fat wires I've added that won't fit inside existing conduit, I just zip tie it to the outside. Neat wiring stays out of harms way and makes everything look a lot better.
  3. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    plastic or metal conduit? got a pic? I've thought about doing that.
  4. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    If it is a serious problem, go yank a harness from the junk yard that isnt touched, look for suburbans in the same years as your blazer, my father and I did this for his and then bought plastic wire loom at a parts store and it looked nice ,clean and new, also look into cleaners for electric parts and clean up everything while you are at it. /forums/images/graemlins/thumb.gif
  5. Blue85
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Plastic. Strictly plastic automotive "convoluted tubing". Don't use anything that's intended for home wiring.
  6. glencanyonexplor
    glencanyonexplor Registered Member
    Jul 14, 2002
    26
    Arizona
  7. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    I'm going to steal some ideas from you, thanks. Glen whats that extra fuse panel/relay center on your drivers well? and on your 205 what is plugged into the passenger side detent ball/spring location page 2 truck 006?
  8. glencanyonexplor
    Jul 14, 2002
    26
    Arizona
    Thats a power center from a newer dodge truck,I wired every thing to fuse's and relays.with the relays it takes the load off of the switchs and supplys alt voltage about 14.0 volts to everything.
    that switch on the 205 is the 4wd indictor lamp sw.
