My engine ODed on coolant via Felpro intake gaskets!
Discussion in 'The Garage' started by BigBurban350, Oct 1, 2005.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Has anyone seen this before? (how the gasket is streched)
    I don't think I forced the gaskets like that to rip it, its odd how the holes are elongated. Right now I can only think of heat expansion causing this.
  2. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    looks like over tourqed my self.:o
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Yup, looks like it to me as well, and maybe the surfaces weren't perfectly cleaned and smooth before applying the gaskets?
    (thats just a guess though)
  4. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Come on now, I want to blame somebody else!
  5. 4xcrazy
    Oct 31, 2003
    9,472
    5
    ok, then blame the person that did it, if you did it, then blame the person you WERE going to have do it, for not doing it, and forcing YOU to do it. :D
  6. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    agreed
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Ditto....you didn't RTV the coolant ports along with the gasket? I've done that on all the motors I've worked on before. (5)
  8. OLD DAWG
    OLD DAWG 1/2 ton status
    Jul 20, 2002
    444
    MONTROSE, COLORADO
    You can blame me for it my wife always does :crazy:
  9. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Do you put RTV on the gasket itself, or around the gasket area?
  10. 4xcrazy
    Oct 31, 2003
    9,472
    5
    I always just throw a thin coat on the gasket and mating surfaces around there, just alittle extra insurance against leaking.
    Looks like you used the end rubber gaskets as well, MAN those suck,,,literally :doah:
  11. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    Don't go crazy but if you want it to be sealed up use rtv on everything... intake ports, water ports, and where you used the black rubber gaskets(front and back of the block).
    I use it on both sides of the gasket...
  12. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Thats the part number dart gave me, oh well.
  13. sweetk30
    Nov 1, 2004
    25,548
    543
    go get new set. open box then throw out end seals. use black rtv on neds 1/4" thick. apply the red tack&seal from locktite/permatex to the intake ports. and use small amount of black at coolent ports.
    but first make sure all surfaces are clean.:D
