My Engine Sucks
Discussion in 'The Garage' started by bgchvy79, Mar 6, 2004.
  1. bgchvy79
    bgchvy79 1/2 ton status
    Jan 3, 2004
    108
    Moore, SC
    Aight guys, I'm finishin' up the first stage of my truck, and It's been sitting since October w/o running, and so today I'm out there and I turn the key and the engine just spins. We poured gas in the carb and it did no good, we've torn my distributor all apart and put ti back together and checked plug wires and replaced plugs and we can't figure it out, do any of ya'll have an idea what it could be? Also, the distributor was installed new the day before I parked it, so I'd imagine it's still fine...
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    do you have spark? im guessing its in the electrical /forums/images/graemlins/thinking.gif
  3. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    The distributor's probably not in right, that's the last thing that was touched and all.
  4. t's85chevyk5
    t's85chevyk5 Registered Member
    Jan 29, 2004
    66
    Phoenix, AZ
    possibly bad gas?can you smell if the engine is getting any gas? /forums/images/graemlins/dunno.gif
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    492
    Grand Rapids area
    All engines suck. That's how they draw the air/fuel in /forums/images/graemlins/whistling.gif
    If you look down the carb and see a shot of gas when you pump the throttle, then the accelerator pump is working. Based on this alone, you should be able to get enough fuel for the engine to fire a couple times. Have you put a timing light on it?
  6. bgchvy79
    Jan 3, 2004
    108
    Moore, SC
    We're gonna try the timing light today, I know it's getting gas b/c we poured some straight into the carb. Also, the distributor was working fine after installation, I drove it home that night and to school and back the next day w/o it missing a beat...
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Did ya flood it????
  8. bgchvy79
    Jan 3, 2004
    108
    Moore, SC
    I don't think so, we didn't pour much in there and it was just turnin' even b4 we put some in there
  9. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Make sure you pull the plugs and either change them or clean them real good. I had the same problems some time back and it was not starting because they were soaked with fuel. Quick change, adjust timing and ignition!
  10. bgchvy79
    Jan 3, 2004
    108
    Moore, SC
    Plugs are fine, but we decided the distributor is fine b/c we tore it apart and replaced everything, the wires are brand new, I bought 'em yesterday...anybody have any more ideas?
  11. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Does it have spark?????????????????????????
  12. bgchvy79
    Jan 3, 2004
    108
    Moore, SC
    Nope. Not sparkin', I got my brother to stick his finger in the boot while I turned the key...
  13. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Do you have 12v to the coil and is the wire plugged into the batt side of the coil?
  14. bgchvy79
    Jan 3, 2004
    108
    Moore, SC
    Yep....I'm beginning to think the truck just hates me...
  15. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    If your distributor is getting 12v when cranking and its not producing any spark then its time to look at the distributor. Remove the cap.....is the rotor turning when the engine cranks? If so the next step is to check the module, auto parts stores can usually check them or if you have a spare you can throw it in and try it. The next step (if the module is good) is to check the pickup coil. Good luck /forums/images/graemlins/thumb.gif
  16. bgchvy79
    Jan 3, 2004
    108
    Moore, SC
    The rotor is spinning, we checked that when we found TDC to make sure the wires were on right, and also I installed a new coil today and I'm not sure about the module, I'll have to check on that...I guess that's the only thing it could be
  17. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    What year/make/model are you working on?
  18. bgchvy79
    Jan 3, 2004
    108
    Moore, SC
    Well, that's a long story, but I'm pretty sure the engine is between a 75 and 80, the front of the truck is a 79 and the rest is an 81, it has one axle out of a 73 blazer and one out of a 78 suburban amd right now the truck is a K10, but to add to the fun, that engine was swapped in before I got the truck, so I know very little about it. It is a 350 though, and when I replaced my oil pump the gasket I used was off of a 75-80 350...sooo i'm not sure if that'll answer your question or not.... /forums/images/graemlins/dunno.gif
  19. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Ok, so it has an HEI distributor, right? When you say you already replaced the "coil" Im wondering if you replaced the ignition coil that sits on top of the dist cap. There is a pickup coil as well. If the module tests ok the next step would be to remove the distributor and replace the pickup coil. Keep in mind that often you can buy a brand new HEI distributor at speed shops for around $149 which include everything so dont waste too much $$$ on your old one. Good luck /forums/images/graemlins/thumb.gif
  20. bgchvy79
    Jan 3, 2004
    108
    Moore, SC
    Where is the pickup Coil?
