My find!!
Discussion in 'The Garage' started by big pappa b, May 15, 2003.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I went out tonight and got a SM465 tranny, bellhousing and shifter for $100.
    After that we got to talking about another truck he has.
    It's a 72 3/4 ton-D60front and eaton?? 14 bolt rear, haven't heard of an eaton rear only eaton differential (HELP) - SM465 w/PTO connected to a 10 ton PTO winch - 307 motor, truck runs....How does $700 sound...I think I'm gonna get it /forums/images/graemlins/thumb.gif
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    What did the D60 front come out of?
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    you think? heh you should know. if it is a d60, then buy it up, Even though they dont make parts for those Eatons anymore, they are tuff as nails...
  4. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    The D60 is supposedly the original in the truck
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    then wouldn't that make it a 1 ton and not 3/4???? /forums/images/graemlins/thumb.gif /forums/images/graemlins/deal.gif
  6. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    3/4 ton in any year will be a Dana 44. Is it open knuckle or closed?
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    they didnt put 60's in until 77'
  8. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    According to this , as I suspected, D60 not available in GM trucks in 72.
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Wes (thatk30guy) would know for sure, but I thought that the Dana 60 wasn't installed in GM trucks until around 1977.
  10. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Gonna have to get a better look at it. It was getting dark and I had no light
  11. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    You are correct.
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Looks like a lot of us were thinking the same thing. /forums/images/graemlins/eek.gif
  13. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    So I should be able to tell by looking at the knuckles to see if they are open or closed? Is that the only way without taking the cover off and measuring the ring gear?
  14. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Are you referring to the difference between the 44 and 60?
  15. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    oops, yes. the 44 and 60
  16. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    The 44 will have ball joints on the knuckles, the 60 will have kingpins. That is the quickest way to tell by eyeballing, IMO. Otherwise, the model # of the axle will be cast into the webbing on the bottom driver's side of the pumpkin, right below where the axle tube presses into the centersection. Another quick way-the 44 steering arm is held on with the 3 nuts, 60 arm is on top of the knuckle with 4. Hope that helps some. /forums/images/graemlins/smirk.gif
  17. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    A factory 1972 D44 will have open knuckles & disc brakes, so will a 71. 1970 was open knuckle drum brakes. 1969 was closed & drums.
    As stated above, D60 was first installed factory in 1977, it was an open knuckle, disc brake axle. /forums/images/graemlins/thumb.gif
  18. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Cool, I sent that to the guy and will have him check it out tomorrow. It's about 90 miles from me so I can't just go check
  19. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I know for sure it has disc brakes and 8 lugs on the wheels
  20. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Crawl under it with a rag, and a flashlight, on front of the housing, lower, right hand corner, the model is cast into the housing, either D44 or D60
    60's did'nt appear as O.E.M. until '78 I beleive. I know the first gens, did'nt have them.
