MY FIRST DRIVELINE PROBLEM!!! **how much shimming will i need?**
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Sep 23, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i don't know wether to cry or laugh, /forums/images/icons/crazy.gif i feel like a real wheeler now. /forums/images/icons/shocked.gif
    as some of you know i installed a set of hill shackles and i just ran it up and down my road in 4-hi and at about 30 mph i'm getting a noisy vibration. the CV is not hitting the crossmember so i assume it's the u-joint yelling at me for running at at that angle.
    obviously i need shims, so my question is will the shims that were on mudbogAD's jimmy with the 2.5" lift work for me or do i need a specific size? i have 4" springs and 1" hill 4wd shackles and a stock driveline.
  2. muddysub
    Jun 23, 2001
    10,451
    489
    Re: MY FIRST DRIVELINE PROBLEM!!!
    anyone? /forums/images/icons/confused.gif /forums/images/icons/frown.gif
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You need whatever shims are going to make the pinion point about 2-4 degrees down from being right in line with the driveshaft... Hard to say exactly whcih ones that those are going to be.</font color>
  4. muddysub
    Jun 23, 2001
    10,451
    489
    does anyone else have this setup? if so how much did you have to shim?
  5. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    We installed the H4WD shackles on ducttapes K10 longbed with 4'' TC-HD springs. We left the axle where it was. Caster angle is more important than pinion angle on a DD. Does it handle the same as before better/worse? You could try a 2-3 degree shim for starters, that should get your pinion back up enough to cure your vibes. I would recommend taking it to an alignment shop and have them check your caster angle and go from there.
  6. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    If you have rear blocks then you can replace them with angled blocks in the rear for pretty cheap. With 5" of lift I would be more worried about driveline length than angle. Your sub is long enough to not have angle problems until you get 8 or more inches of lift. What have you done to your d-line? If it is still the stock length then that could be the problem, not enough in the slip shaft letting it vibrate around a little.
  7. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    The product review (done when Steve Fox was running the Hill Shackles) says that Brennan (sp?) Hill suggested a 3 degree shim...but Steve went with some 2.5's he already had, Rancho part number RS8125 with no problems.
    On a different note, did you measure exactly how much lift it gave you? The UAV gained 1 5/8 inches between the shim and shackles. I'm considering this go complement my 4" TCHD springs up front, and junking my rear blocks and 10 leaf one-ton springs for some 6" TC springs. Just not sure if the shackle alone will be enough up front. If if nets 5.5 total up front, thats close enough for me.
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Remember High School geometry? This is what it was for. Measure the distance between the spring eyes then find the difference in length of the shackles. Stock ones are 4", Hill's are 6" or more. Using the front spring eye bolt as the center of an imaginary circle, the rear spring eye has traveled in an arc a little more than 2". The circumference of the cirle is 2*Pi*(distance between eyes). Divide the arc length by the circumference and multiply by 360. This is how many degrees you have moved your pinion.
  9. Grim-Reaper
    7,385
    Atlanta
    OK Since you talking CV and CROSSMEMBER I believe you talking about the front drive shaft and I seem to recall your truck is still fulltime. 4 inch lift needs about a 2.5 degrees. That's what it took on my 75 and it ran down the road vibration free when it was still full time. With a BURB and a 203 you do not need to lower the t-case. plenty of rear driveline and lowering the case makes the angle on the CV worse. The reason being is your tilting the case down and the front output will point up more.
  10. muddysub
    Jun 23, 2001
    10,451
    489
    no i have an 89 with a NP241. i'll check on the 2.5deg shims
  11. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I have a six inch lift on my k20. I did the hill shackles too. I have I think 4 degree shims in the front. Every time I went wheeling and used 4wheel drive my driveline would make a not so good of a sound. So this is what I did.
    I did some work on the cross member and ground on the driveline stops. Now when I go wheeling The driveline dose not hit the cross member and the stops do not hit. If you want pictures I can get them.
    Colin
