My first long distance towing trip...
Discussion in 'The Garage' started by MEPR, Apr 30, 2005.
  1. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    So i towed the LUV home whith the K-5 this weekend. It was sweet, i could tell the K-5 was protesting a little bit (208 gears 305 and a 700r4 makes for a great tow rig! :grin: ) but it towed the LUV whithout a problem. Well then day 2 of the towing weekend comes along and i drive up to mountainexplorers place to rescue the ford. We get the F-150 winched onto the trailer and hit the first problem. The straps arent designed for 33" swampers, so we air the tires all the way down and then i was able to strap it down. Now i have said 305 700r4 whith 308s K-5 pulling probly around 6,000lbs. Awsome. The truck had no problem pulling it (it just acted like it whanted to pull torque wheelies :cool1: ) so i was on my way. Stops fine steers fine all is well, untill im going down hill and trying turn. Now i dont know what protocal on something like that is but i was able to keep it all in my lane so i think i did well. But the trailer started pushing the rear end around so the k-5 started swerving back and forth. What i did is at fist think of hitting the brakes but thought that would probly kill me, so i let of the pedal and held the wheel as straight as i could and when that didnt do it i eased into the gas and powered out of it. Is that kinda what your suposed to do? Well at any rate the K-5 impressed me in the past 2 days and i dont think ill ever tow another full sized truck whith a k-5 :blush:
    And on a side note i stopped after all the big hills to check on the tranny fluid and it NEVER go too hot to handle. I was able to hanld the ATF more than my upper radiator hose, so using this my tranny should be running perty cool right?
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    LOL, a blazer is a terrible tow rig.....but it is fun. I've pulled a lot of junk with my K5, especially after my 3/4 ton swap. If you thought your stock truck was bad, try pulling with it 10" in the air and on really wide 35x16" boggers. :D I also hauled an F150 one time that probably grossed around 7K including the trailer. It pulled great, even with my tires and heigth. I've got plenty of power though. :p: :grin: I've hauled farm equipment, pulled disks, large field mowers, and hauled lots of semi truck parts on trailers with my K5. The most weight I think I ever pulled was about 8-9K, slightly heavy. I even pulled a gooseneck once. :D
  3. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    yeah im going to swap in some 4.10s when the LUVs V-8 swap is about done so i can tow it to the track :cool1: But for just 308s in it now it impressed me (granted i have only ever owned mini trucks so its not hard to impress this guy :blush: )
  4. Storm Trooper
    Nov 24, 2000
    4,640
    I agree with rjfguitar, a K5 is a poor tow rig because of it's short wheel base.
    as for
    I've found that when things start to get a little squirrly, I use the in cab trailer brake control to slow it down. If it's only slight, I will add some power to pull it straight. If you don't have electric brakes on your trailer, you shouldn't pull anything heavy.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    how exactly does one pull that off? expecially with a lifted truck.
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :tongue1:
  7. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    well this towing weekend was a one off deal for a few reasons...
    1 308s
    2 700r4
    3 weenie wheelbase
    4 i had some junk that had to get home
    And i would have used the trailer brakes but i dont have any. This was U-haul car trailer (quiet i only ever towed a 2wd 80 LUV :blush: ) so it had inertia brakes i think, but they sucked and didnt do a thing.
  8. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    They are called surge brakes. There is a plunger inside the hitch and when you hit your brakes the ball pushes that plunger back which then pushes hydraulic fluid to the brakes on the trailer. I also rented a United Rentals trailer once with surge brakes and felt they weren't helping much. I don't think the design is all that bad, it was fairly popular, even though electrics are better. I think the main problem is maintenance on those rented trailers, I would guess it's pretty poor and in both our cases the brakes on the trailers needed rebuilding.
