My first tranny install, and I have a question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5thatShmobs, Jan 6, 2003.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Alright, I put the new tranny up on my '89 (700R4) and bolted the bellhousing up, and noticed that the torque converter holes that fasten up to the flywheel are about a half to three quarters of an inch away from the holes on the flywheel. Problem? Any suggestions?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    No problem. You can spin the converter untill the bolts line up and slide it forward to the flexplate. /forums/images/graemlins/thumb.gif
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    par for the course. spin it around till they line up.
  4. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    thanks... here goes nothing
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I'm not understanding if they aren't lining up like you need to spin the torque converter.. or like there is a gap and you need to tighten the bolts up to suck up the torque converter against the flexplate.
    You should be able to move the torque converter easily.
    If you can't move the torque converter back and forth a little, and spin it freely with very little force...
    Then the torque converter is NOT indexed into the oil pump in the front of the tranny... and it will be binding up. /forums/images/graemlins/grin.gif
    I've done this a few times while installing a tranny.
    ya get the tranny all bolted up to the engine and then realize the converter wont spin.
    Gotta drop the tranny back, take out the torque converter a little ways spin it then push it back in and try to get it to drop into place.
    Good luck. /forums/images/graemlins/thumb.gif
