My fishtank stinks, what to do?
Discussion in 'The Lounge' started by mofugly13, May 19, 2006.
  1. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I have a freshwater aquarium and lately the water has started stink like a rotten egg. I do the 25% water change every other week, condition the water, vacuum the gravel, etc. I don't know what the cause is. The only thing I can guess is that I replaced the 6 year old bio filter with a brand new one about 2 months ago. I didn't put any of that nitrifying bacteria that you're supposed to add when you start a new tank, to help with biological filtration. Could that be it? I added the recommended dose today, hoping that helps. but it REALLY smells bad. The water is clear, and the fish seem happy, but my GF and I aren't happy, the stank is ridiculous. I have had this particular aquarium running for about 10 years now, and tis is the first time I've ever noticed anything like this. Any ideas?
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    You have showered lately, haven'y ya? :wink1:
  3. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    OK, you're gonna think I am being a smarta*s, but are you sure it is the water and not a little feeder fish or something rotting behind the tank?
    How many gallons?
    Undergravel filter?
    What kind of fish?
  4. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    filter?
    Does your new filter system use carbon, that helps control odor.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    That's what i was going to say, sounds like it needs new carbon or,,,,i forget what it is, but it's white, and helps control ammonia and other odors as well.
    I use the comdo stuff, carbon and that stuff, works real good, I usually don't have to mess with the filter, but once a month or so.
    Also, if your tank has been up and running for awhile now, i personally wouldn't do the 25% water change as often as you are, maybe like once every month or even once every other month, don't clean the gravel that much either, this is part of where your bacteria is comig from you need in there, don't over feed, this is the main cause of alot of "crap" other than crap in the gravel.
  6. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
  7. docgab
    docgab 1/2 ton status Premium Member
    Oct 1, 2002
    1,166
    Medford, OR
    you should get a water test kit. It would answer real quick if your water isn't where it should be. After two months you should already be done withe cycling the tank unless your tank is very lightly populated.
    What size tank, what kind of fish, how many of them etc would be useful as well. :-)
  8. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Sell the fish in China Town and use the tank as a target:D
  9. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Ha ha, corey. Little appetizers! My tank is a commnity tank, some guppies, mollies, tetras, a pleco, and a bottom feeding cat. Stinks like poo.
  10. 4xcrazy
    Oct 31, 2003
    9,472
    5
    what size is the tank, and exactly how many fish do you have in it?
  11. docgab
    Oct 1, 2002
    1,166
    Medford, OR
    yeah and exactly what type of filtration are you using? undergravel, hang on tank, canister etc?
  12. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    It's a 20 gallon tank with a hang on Bio-Wheel filter. No undergravel filter. I didn't really have the stank until I bought a new Bio-wheel to replace my old azz one. When I did replace it, there were only 3-4 small fish in the tank and I did a super thorough vacuum ofthe gravel as well. I thought that there should have been plenty of bacteria left to establish a new colony on the bio wheel, but aftr two months of running the new filter, the wheel looks brand new, no discoloration or noticeable 'growth' of anything on it. I thought the lack of nitrifying bacteria might be the culprit, so yesterday I added a bottle of live bacteria to the tank, hopefully that will take care of it. Could that be the cause of the stink, not enough bacteria? If so, then I think I'm on th eroad to recovery.
  13. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Possibility, give it some time now, and keep replacing the carbon in the filter pads about every two weeks and see if anything changes, don't do anymore water changes for awhile, i don't think you have enough fish in there to justify a water change every two weeks.
    Go easy on the feeding too, not too much, that stuff turns to crap, and not through the fish either.
    That's another thing,,,how often are you feeding them, and how much?
  14. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    I feed them once a day, about as much as they can eat in 3 minutes, which is just a hefty pinch of flakes. My bottom feeding catfish does a really good job of getting rid of any leftovers. I'll stop the water changes for awhile, go once a month or so from now on.
  15. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Maby your pussy needs a duche.
  16. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    Over feeding will do it,and make sure there is no dead ones in there some where.
    Becareful not to change the water to much you could kill the fish. underground filters do help alot when used with bio filters.
  17. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
  18. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Over feeding causes most of the problems people have.
    Not a big fan of undergravel filters.. they can keep a lot of crap stuck on the bottom of the tank that will eventually kill the fish.. ( ask me how I know)..
    My 45 gallon just uses dual bio-wheels, with pass - through carbon packs, and I stick bags of chemi - pure in the media resevoir.
    I'll change out maybe 20 gallons of water every 8 weeks, ( while vacuuming the gravel) and add some ammo - lock for dechlorination purposes.
    best way I found to vac the gravel is this.. once I fill the vac with water, I keep my finger over the hose end.. then, I stick the vac straight down into the gravel, as far as it will go.. then I take my finger off the hose, and let the water come out until it runs clear.. then I put my finger back over the hose, and pick the vac end straight up, then back down, right next to the spot I just did, and repeat the process. It works best with a larger vacuum.
    It's a bit more tedious, but it gets everything, and keeps the crap from clouding the tank while I'm trying to clean it. By the time I'm done, I've removed about 20 gallons of water.
    Maybe doing it this way will help remove the stink problem.
    Pics are of my 6 year old pink gourami, and my geophagus cichlid..
    Tom
  19. docgab
    Oct 1, 2002
    1,166
    Medford, OR
    I'm not a big fan of undergravel, although I like the reverse undergravel filters better.
  20. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    That's about how I do it. There are no dead fish, and I don't overfeed, I'm hoping the lach of beneficial bacteria has something to do with it.
