My frames a crackin'!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redfrog, Jul 9, 2001.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    My frames a crackin\'!!!
    DAMN, well time to get a brace. I do have a question though, does the ORD weld on kit wrap aroud to the bottom of the frame?
    I do need to remove the stearing box correct? TIA
    HEY Fords!!! how many flushes does it
    take to get rid of you
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Re: My frames a crackin\'!!!
    I believe that their kit is the same one that Four Wheel parts and everyone else sells. If it is the same, yes, it does wrap around the bottom of the frame - at least mine does, and I got mine from 4WP...and yes, you do need to remove the box.
  3. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    It doesn't actually wrap around but it does come in 2(or 3, don't remember) pieces that will accomplish the same effect. Yes, you do need to remove the steering box.
  4. angelglo
    angelglo 1/2 ton status
    Aug 4, 2000
    105
    S.F. bay area
    hey, look into the ord bolt on brace that bolts all the way to the center of the cross member. its a pretty beefy brace. i had a welded one on my other 75. it was good put i put it on after it cracked. the welds held but it cracked again on the brace when i went wheeling one day. the ord bolt on one also bolt on to the back of the box so no removal is necessary. its been working great with my 39's. VERY easy installation also
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    The weld on kit comes in 2 pieces of 1/8 material.
    One big huge piece for the side that goes behind the box and 1 smaller piece that goes on the bottom lip of the frame.
    You will have to get longer bolts from your local bolt supply house. With the brace and the weld on kit, the supplied bolts aren't long enuff to secure the box.
    When in doubt.....Use the Saws-all[​IMG]
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  6. Redfrog
    May 4, 2001
    753
    IL
    thanks everyone I'm going to tear in to it on Sat.
    let the fun begin!!!
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    yell-come[​IMG]
