My fuel gauge is messed up.....can anybody help?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sax Art, Dec 18, 2000.
  1. Sax Art
    Sax Art Registered Member
    Dec 12, 2000
    49
    Western, Wisconsin
    I've got a 1991 and the fuel gauge will read fine, then spikes up to waaaayyy past the full mark. If I tap firmly on the gauge's glass, it will (sometimes) fall back down to reading the tank's actual level, but then it will later go back to waaaaayy past full.
    I'm thinking it's just a bad ground or a loose wire, but I'm just wondering if anybody else has had this problem. Maybe then, I'll know what to look for when I open up the dash!
  2. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    I had the same thing happen on my 70, (except for the tapping it and it moving), and it turned out to be the ground wire back at the tank was very lose.
    [​IMG] I have to agree with the Puddy Cat. [​IMG]
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you are right check your ground wires clean and make sure the wires are firmly attached to the gauge
    s.smith 77blazer lookin 4 mud
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, GM gauges use a 90 ohm sending unit. 90 ohms of resistance is "full", anything less moves the needle towards empty. An open circuit is infinite ohms, so the gauge goes way out past full. (To about the 3 o'clock position on one of the full size gauges). Somewhere you've got a loose connection in the fuel gauge circuit.
    http://ThunderTruck.ColoradoK5.com
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would say that if you can tap on the dash and it fixes it then check behind the dash first
