My Full Hydro Is coming together***Updated With Pictures***
Discussion in 'The Garage' started by ProJunkRacing, May 12, 2006.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    Well my full hydro is coming together i wish it was done already since , i really need to have steering for the local mud runs in 4 weeks. What I did was i cut my old steering shaft right about 8 in from the rag joint then i had a shaft for my orbitol valve. So i welded a mount onto the frame and the steering shaft goes right in just like a gearbox so it is coming together . I do need to get a seal for the orbitol measured but i have not had time yet . All i need to do really is route my lines and mount tabs that my friend is having a metal shop punch in 1" plate for the mounting tabs. Here are some pictures of how i mounted the orbitol valve.
  2. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    i just noticed how sad it is on little tires lol
  3. Orange Crush
    Orange Crush 1/2 ton status Premium Member
    Mar 6, 2003
    440
    St.Stephen S.C. 29479
    What kind/size ram are you going to use?
  4. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    2in bore 8in stroke implement ram
  5. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Do you have any pics of your ram mount? I am going to go with full hydro also, and this is just one of the stumbling blocks I have run into.
  6. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    lookin good, i hate seeing trucks on "mall marcher tires" =( its sad but in the end its all good. i like the beginning of full hydro, BUT just curious why you didnt laeve the rag joint, in case of body flex between the colomn and the valve...
    LUKE
  7. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    i dont have my mounts done yet having a steel fab guy do them i will have pics on monday i hope.... also as far as the rag joint the only reason i didn't leave the rag joint because that is the connection between the steering shaft and the gearbox . the part of the shaft that connects to the colum has play in order to move and extend as well .
  8. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    I will be on the look out for them then, thanks.
  9. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    yeah it took me alot of talking to others searching pirate etc to decide where to mount my ram i will draw a diagram in paint and post it here in a few mins
  10. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    I agree there is not much info on this subject to be had anywhere, any help would be greatly appreciated.
  11. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    ok here is what i am doing it is a very rough sketch as well .
  12. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i think it looks better with the small tires haha
  13. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    I finished it last night
    well I finished my full hydro last night i made my own tabs out of 1" plate and it worked great . Here are some pictures
  14. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    here are a couple other shots
  15. jaysonsk5
    jaysonsk5 1/2 ton status
    Aug 11, 2005
    229
    eastern iowa
    do you have it working?
  16. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    yup works great
  17. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I would mention it again. I think, IMO, you should have some kind of rag/u-joint in that shaft. I do realize that it slips in/out at the top, but it doesn't really allow lateral movement. And chevy's flex alot as we all know.
    Other than that, I think it looks great!
    John
  18. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Looks good man! How much time do you give that tie rod till it expires?
  19. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    hopefully a few trips lol i am on the lookout for one but i need this thing done so yeah i just got my trailer today now needs two tires ,and do exhaust on the trail rig
  20. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i was jus goin to say the tierod is the point. looks good tho. so how soon u goin to go wheelin?
