My gauges are all broke, why?
Discussion in 'The Garage' started by dodgetruck91, Feb 20, 2003.
  1. dodgetruck91
    dodgetruck91 Registered Member
    Oct 22, 2002
    99
    New Berlin, Wisconsin
    i just bought a 87 K5, my fuel read full tank, my oil pressure is stuck at 60, my temp is all the way up. does anyone know why this might be, i tried looking for the fuse but i cant find it. and if its a bad ground, where would i find the main ground connection for the gauges? thanks, john
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    check the ground wire /forums/images/graemlins/shocked.gif
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I know you have allready looked for the fuse, but if it's not labeled I would pull all the fuses out one at a time and check them all. Or if you have the owners manual, maybe it will have it listed in there with a diagram or picture.
  4. dodgetruck91
    Oct 22, 2002
    99
    wheres the ground wire? thanks. /forums/images/graemlins/k5.gif
  5. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Also check the plug on the back of the gauge cluster. Mine turned out to be only half way plugged in.
    John
  6. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    The body ground wire could be your problem. Follow the smaller of the 2 wires that come off the NEG terminal of the battery, it should bolt to the body not far from the battery. The bolt could be loose of the wire could be frayed.
