My gears fixed my speedo needle???
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Chris_T, Jun 15, 2002.
  1. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    OK, this is starting to tease my brain a little. I swapped from 3.73's to 4.56s and it 'fixed' my speedo. No, I don't mean that it reads correctly now, what I mean is this: With the 3.73s once the needle got around 55-60 it would start to wave back and forth - sweep from 50-65 or so. Somehow after my gear swap the needle is solidly on whatever speed I'm going. My question is why? The cable didn't get touched, neither did the guage cluster. The rotational speed of the cable hasn't changed since it's off the T-case .. not that I'm complaining mind you, but it's just teasing me .. why did it fix itself? Now if I can only get the rest of the truck to start fixing itself.
    Blazer heal thyself
    CT
  2. blazingjesse
    blazingjesse 1/2 ton status
    Mar 13, 2001
    159
    kayenta, AZ
    call it lucky. you did something right.
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i wish if i replaced something something else would"fix itself".would be nice
