My Head is spinning
Discussion in 'The Garage' started by 1987Blazer, May 15, 2005.
  1. 1987Blazer
    1987Blazer 1/2 ton status
    Apr 9, 2005
    Murrieta CA
    A couple months ago I became the proud owner of a 1987 K5 Blazer. I had it a couple of days and decided it needed to be covered in mud (just so I could say she was mine). Make a long story short I broke a spidergear in the rear axle.I also think I broke something in the 208 transfer case. I have been looking around on this forum and decided to swap out the 10 bolt axles. I already have a 14bff for the rear and am looking for a D60 for the front. This seems to be the route everyone has gone.
    I will be running 35" tires on 16" rims.
    This is where my head starts spinning with all the information from CK5. :confused:
    With 35" tires it looks like I need to run minimum of 6" of lift. Or do I need more? I currently have a 4" lift with blocks in the rear. So I need some oppinions on the best way to go about lifting the blazer. What will give the best articulation? 6" lift with new leaf springs all the way around? or a shackle flip with what springs 54",56" for the rear? What should I do to the front?
    Also I need a transfer case I have a 350 motor with a 350 trans. I have been thinking of trying to fine a 205 but it sounds like they my not be the perfect choice. My other Idea was to go with a NP241 with a slip yoke elimintor kit.
    Any comments on these two Ideas.
    I don't have a money tree in my back yard but I believe in doing things the right way the first time, it ends up being less expensive.
    Thanks Steve
  2. southernspeed
    Dec 24, 2003
    IMO stick with the 4" to keep your CoG low and cut the fenders for clearance. That's my chosen route!
    As for the t/case, 205's are generally considered about the strongest and most plentiful. Heavy but strong. And if you pick up a cheap 203 in your travels one day, you could build a doubler!
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    Great Falls Mt
    You'll need to trim a little to fit 35's on a 4 inch lift. Put it all together first, then flex it to see how much.
