My hood doesnt pop open, what do I do?
Discussion in 'The Garage' started by afroman006, Mar 7, 2005.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    My burb has over 200k miles on it and the hood has probably been opened way more times than it was designed to. Now, when I pull the cable, nothing happens. It pops the latch but the hood doesnt pop up. The cable is not the issue, I just replaced it. The brand new one I just put in was the same damn length as the old one so I did some creative work with some bailing wire and its as tight as its gonna get. I'm thinking I either need to replace the little coil spring at the front of the hood, or the two big hinges that support it. Which is it. Right now I have to beat on the driver's side corner of the hood to get it to open and its dented, and my hand is starting to hurt. For labor's sake I hope its just the little spring at the front but I will do whatever needs to be done to fix it.
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Have you tried lubing it all. The hindges, springs, everything that moves on it. I did that to mine and it work.
  3. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I thought they all came with the "saftey lock" aka beat on the hood. :xmas:
  4. afroman006
    Aug 21, 2002
    2,876
    Noooo. Good idea. I'll try it and report back.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    open it up, grab snatch ahold of the spring, and stretch it back out. then go get yourself a new spring sometime in the near future.
  6. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    cheby tap
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i just squirt a lil wd40 on mine. works like a charm til it gets dirty again. i have to pop mine right in the middle. i think its kinda cool, like the fonz.:D besides lube, a new spring would probly solve it tho.
  8. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    It's all in the wrist..... :D
    Mine has this security feature also.
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Hah, I'm having the opposite problem as you....mine wants to pop open all the time. :haha:
  10. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,008
    841
    Pinckney, MI
    Do what I did replace your power steering pump, then leave a bottle of power steering fluid in the center by the latch. Now wait till it gets dark to shut your hood and forget about that bottle. Then you realize what you did and feel like a dumb ass. Next day you pop the hood, and it actually comes open :thumb:
  11. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    What? You mean thats not the factory anti theft device? :xmas:
    Do the quick beat on the left and right side of an emblem. usually a good 10 seconds of beating it works for me.
  12. afroman006
    Aug 21, 2002
    2,876
    The beating *would* be cool if it weren't for the violence required to get it to open, and the dent in the hood.
  13. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Have had the same problem with every Chevy truck I've owned, and I just beat on the hood, until last week. I noticed the rubber hood bumpers on the front left and right hand corners under the hood screw up and down (I don't think the older ones do, and I don't know what year they changed, but I have a 87 Burb). I gave them each a little twist so they stick out a little farther, and voila, the hood has popped right up every time since. Please post up if this works for you, or if I just got lucky.
  14. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    pull latch, walk to front of hood, hit hood twice, pops up :)
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    yep, the "Chevy LOVE tap" is what your rig needs.
  16. gar
    gar Registered Member
    Mar 3, 2005
    10
    Concord, CA
    I've found that the tap does the trick. To figure out EXACTLY where to tap, feel where the hood release in the grile is. Now, figure out where on the hood is directly above the hook, and deliver a quick rap with your fist.
    With a little practice, you'll feel like the Fonz.
  17. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Try WD-40 and stop beating it hard enough to dent it. A light tap will always be required.
  18. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    i had to do the "chevy tap" on mine all the time, then for the heck of it, one day i losened all the bolts on the hood hinges, re-alingned the hood, made sure that all gaps were equal. tighten the bolts back down, and now my hood works fine, pull the lever and it pops right up..granted it took me some time to get it aligned just right..but thats another option to look into
  19. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Me too. I give it the ol' Arthur Fonzarelli just to the left of the centerline, above the grill. Works every time.
  20. dyeager535
    26,979
    They started this as early as 1981.
    This is probably going to fix your problem, it did mine.
    The hood latch assembly is also adjustable up and down, but if your hood lines up with the rest of the body, then mess with the bumpers first. Typically have to close it a bit harder, but it will pop up when you pull the cable. Don't get them out too far, I can imagine having hood problems if they are putting too much pressure on it.
    Mark the hood latch location before loosening the bolts up, and make SMALL adjustments if you start playing with it. If your hood opens ok once you get it unlatched, then its not a hinge issue.
    Actually, I think I'm wrong. The bumpers should set the body line as the final adjustment, the hood latch should be adjusted to allow it to release.
