My K5 is dieseling when I shut it off.
Discussion in 'The Garage' started by badmix, Jan 27, 2007.
  1. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    Its a 305cid w/ 120k on it. It seems to have started when I was monkeying with the carb. But b4 I do anything, I wanna check here and see what ya'll think or recommend. I dont wanna be chasing my tail on this.
    1) Could carb cause this? If so, why? And what adjustments should I make , go lean or go rich?
    2) Could it be a fluke that it does it when I adj. carb and it is really something else, like timing?
    3) If it is timing what is the correct timing for this?
    I appreciate any advice, suggestions, help or comments. :D
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    When you were "monkeying" with the carb, did you bump up the idle? Too high of an idle causes run-on.......
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    If it started right after you messed with the carb, go un-mess what you just did.
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Dieseling can be caused by the engine running too hot. Messing with the carb could definitely cause this if you have gone to a lean condition. Carb adjustment in conjunction with checking your timing would probably cure it.
    Something that may be helpful to others posting is if you tell us why you were messing with the carb to begin with
  5. badmix
    Nov 7, 2004
    4,205
    60
    West Virginia
    I was messing with it when I went up to WV this xmas time. The air temps and altitude made the truck run bad. So I monkeyed with it to get it run good up there and then when I got back here I re-monkeyed with it. lol. I used the vacuum gauge approach to adjusting the carb. I guess I need to take my time and monkey some more with it. lol.
